I am running Ubuntu 16.04. I have two Intel Xeon E5-2683 V4 CPUs. Each CPU has 16 cores and 2 threads per core, but the system monitor only shows 58 processors. Why does the system monitor only show 58 processors?
Asked
Active
Viewed 1,006 times
If it makes you feel any better I also get 58 CPUs in system monitor on a 4x24-core system :) But
cat /proc/cpuinfo
Showed 192 CPUs. Then i decided to check perf. So i installed
sudo apt install sysbench
Then i ran
sysbench --test=cpu --cpu-max-prime=200000 --num-threads=200 run
It reported total time: 4.81s
Then i ran
sysbench --test=cpu --cpu-max-prime=200000 --num-threads=100 run
It reported total time: 7.49s
Then i used info from this link to double check utilization/CPU temps: How do I get the CPU temperature?
So it appears that the system does have and use more than 100 cores even though the system monitor shows 58.
Andrei Pokrovsky
- 131
