10
Possible Duplicate:
How do I run .sh files in Terminal?
I need to install a special patch for vmware. To do this, I downloaded the file and it was the file "linux", a text editor, it looks like this:
#!/bin/sh
case "` uname-m `" in
     x86_64)
         "$ 0" _64 "$ @"
         "$ 0" _32 "$ @"
esac
But how do I run it?
Ruslan
  • 101
To run a shell script you first give it permissions:
chmod u+x nameofthescript
Then you run it. Assuming you're in the directory where the script is:
./nameofthescript
If it needs to run with root privileges:
sudo ./nameofthescript
Use a terminal and enter sh /path/to/script.sh.
For example, sh ~/Downloads/script.sh if your script is in your downloads folder.
Kris Harper
  • 13,705
The file you've downloaded is a script file writter un shell ( the first line are the interpreter). So to launch it, you have to open a terminal, like root45 said, terminal can be gnome-terminal or xterm program. The go the directory where you're shell script is saved (command cd), than launch manually your script : sh yourscript.sh
