126
I have tried entering:
sudo apt install python3-pip
The error I get is:
$ sudo apt install python3-pip
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
    libexpat1-dev libpython3-dev libpython3.5-dev python-pip-whl python3-dev python3-wheel python3.5-dev
The following NEW packages will be installed:
    libexpat1-dev libpython3-dev libpython3.5-dev python-pip-whl python3-dev python3-pip python3-wheel python3.5-dev 0 to upgrade, 8 to newly install, 0 to remove and 0 not to upgrade.
Need to get 1,219 kB/39.1 MB of archives.
After this operation, 56.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 au.archive.ubuntu.com/ubuntu xenial-updates/universe i386 python-pip-whl all 8.1.1-2ubuntu0.1
Ign:2 au.archive.ubuntu.com/ubuntu xenial-updates/universe i386 python3-pip all 8.1.1-2ubuntu0.1
Err:1 au.archive.ubuntu.com/ubuntu xenial-updates/universe i386 python-pip-whl all 8.1.1-2ubuntu0.1
    404  Not Found
Err:2 au.archive.ubuntu.com/ubuntu xenial-updates/universe i386 python3-pip all 8.1.1-2ubuntu0.1
    404  Not Found
E: Failed to fetch http://au.archive.ubuntu.com/ubuntu/pool/universe/p/python-pip/python-pip-whl_8.1.1-2ubuntu0.1_all.deb
    404  Not Found
E: Failed to fetch http://au.archive.ubuntu.com/ubuntu/pool/universe/p/python-pip/python3-pip_8.1.1-2ubuntu0.1_all.deb
    404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I believe we have bypassed the proxy, so I'm not sure why I'm getting '404 file not found'.
muru
  • 207,228
Abisdad
  • 1,361
The first procedure you followed is correct
sudo apt-get -y install python3-pip
But before installing try to update using command
sudo apt-get update
If first did not work then you can also do this using curl
curl "https://bootstrap.pypa.io/get-pip.py" -o "get-pip.py"
python3 get-pip.py --user
Then to verify installation try
pip3 --help
For checking version :
pip3 --version
alvas
  • 3,027
Sai Kumar
  • 2,386
what worked for me
curl -sS https://bootstrap.pypa.io/get-pip.py >>setup.py
python3 setup.py
I fixed such problem by changing Server in "Software & Updates" -> Download from: there I chose different address and 404 disappeared.
Boris
