I'm running Ubuntu 16.04 on an Dell XPS 13 9350 (skylake)
Since the old kernel doesn't support the broadcom wireless card I updated to ubuntu 16.04, coming from 15.10. The 4.4 kernel should support the card. But it still doesn't work.
EDIT: It seems that only starting from the 4.4.1-1 kernel the broadcom wireless card is supported (see Arch Wiki).
So, iwconfig shows the card. Also lspci shows it.
If I type sudo ip link set mywlan up ubuntu activates the card, but somehow recognizes it as an ethernet card. If I click the network Icon on the top right it says "Ethernet Network (Broadcom BCM4350 802.11ac Wireless Network Adapter)". And of course I don't get a connection to any wireless network. So... Any hints on how to change that? Any Ideas?
Greetings
this question is related to No Wireless on Ubuntu 15.10 with Broadcom 4350 Card
EDIT: Output of lspci -knn | grep Net -A2:
3a:00.0 Network controller [0280]: Broadcom Corporation BCM4350 802.11ac Wireless Network Adapter [14e4:43a3] (rev 08)
    Subsystem: Dell BCM4350 802.11ac Wireless Network Adapter [1028:0021]
    Kernel driver in use: brcmfmac
    Kernel modules: brcmfmac
Looks like the right driver is in use...
File properties of brcmfmac4350-pcie.bin:
freebe@ubun:~$ ls -al /lib/firmware/brcm/brcmfmac4350-pcie.bin
-rw-r--r-- 1 root root 626140 Mär 21 13:27 /lib/firmware/brcm/brcmfmac4350-pcie.bin
EDIT (summary): So even with the 4.4.1 kernel ubuntu sometimes recognizes the card as a wifi-card, but most of the time as an ethernet card. For me it actually only recognized the card as a wifi-card once(!), this was at the first boot. This is probably a bug. If anyone has a reliable way to solve this issue I would be very thankful!
freebe
Okay, this was very simple. I should have read the Question I already linked to in the main post more thoroughly!
I just went to http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4.1-wily/ downloaded the kernel image for 64bit systems (.deb-file) and installed it by double-clicking (Ubuntu Software Center). WiFi works now! :))
Thats it... Mui simple, very simple
EDIT: No, not that simple... see main thread -.-
freebe
For me it almost always works with 4.4.0-12-generic, for all the more recent kernel versions it only occasionally works but most of the time the wireless adapter is recognized as an ethernet card and does not work.
