How do you make windows partitions mount at startup with the ubuntu system? I always keep my media and data files on windows partition.
All info above is good - but this is the EASIEST
Use the Disks application - already part of Ubuntu 14.04/16/04, click on the partition, click on the little cog wheel under - for settings. And then Edit Mount Options
  • change settings to NOT start automatically
  • mount at startup
Aveesh
  • 170
All your options to mount partitions are covered in this page.
Ensure you use the UUID for your drive, as directed in the linked page.
Edit: As noted by another member, do not mount your Windows partition that has your OS on it as RW, make sure it's Read-Only! Other partitions that are only used as storage can be Read/Write. I had originally assumed you meant storage drives, not OS drives. Edited for clarity.
Delorean
  • 11,563
