I'm trying to mount a drive with:
sudo mount -t ntfs /dev/sda1 usb
I get this error:
Mount is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
I use:
fuser -m /dev/sda1
and get back a huge list:
/dev/sda1: 1rce 2rce 3rce 5rce 7rce 8rce 9rce 10rce 11rce 12rce 13rce 15rce 16rce 17rce 18rce 20rce 21rce 22rce 23rce 25rce 26rce 27rce 28rce 29rce 30rce 31rce 32rce 33rce 34rce 35rce 36rce 37rce 38rce 39rce 43rce 44rce 45rce 46rce 62rce 63rce 67rce 68rce 69rce 70rce 71rce 72rce 73rce 74rce 75rce 76rce 77rce 78rce 79rce 80rce 81rce 82rce 83rce 84rce 85rce 86rce 87rce 88rce 89rce 90rce 95rce 108rce 109rce 151rce 152rce 157rce 158rce 159rce 160rce 161rce 162rce 163rce 164rce 165rce 166rce 167rce 168rce 175rce 177rce 262rce 264rce 265rce 294rce 307rce 425rce 527rce 566rce 567rce 598rce 683rce 724rce 725rce 726rce 727rce 728rce 810rce 819rce 824rce 827rce 830rce 832rce 836rce 837rce 850rce 863rce 868rce 893rce 897rce 909rce 911rce 944rce 949rce 962rce 979rce 996rce 1026rce 1029rce 1037rce 1038rce 1039rce 1040rce 1041rce 1042rce 1102rce 1229rce 1268rce 1285rce 1323rce 1395rce 1405rce 1413rce 1419rce 1428re 1507rce 1515rce 1527re 1554re 1559rce 1564rce 1585rce 1596rce 1598rce 1602re 1604re 1605re 1607re 1620re 1647rce 1649re 1654re 1656re 1660re 1664re 1665re 1672re 1675re 1680re 1700rce 1703re 1712rce 1728re 1729re 1730re 1736re 1739re 1741re 1742re 1743re 1747re 1798re 1807rce 1809rce 1814re 1856re 1862re 1863re 1877rce 1889rce 1901rce 1907rce 1912rce 1920rce 1928rce 1938rce 1949rce 2067rce 2077rce 2079rce 2097rce 2141rce 2148re 2157re 2164rce 2168rce 2175rce 2200rce 2202rce 2211rce 2314re 2316re 2337rce 2458re 2635re 2671rce 3023re 3041re 3696rce 4095rce 4370rce 4422rce 4782rce 4800rce 4915rce 4922rce 5012rce 5015rce 5053re 5060rce 7686rce 7809rce 13428rce 14203rce 14204rce 14208rce 14283rce 28222rce 28282rce 28284rce 28285rce 28370rce 28372rce 28373rce 28382rce 28383rce 28385rce 28511rce 28521rce 28550rce 28578rce 28591rce 28593rce 28595rce 28633rce 28857rce 28897rce 28910rce 28972rce 28997rce 29092rce 29152rce 29153rce 29226rce
Not sure what's happening. How can I kill all the other connections and mount this drive?
(I saw this similar question but I found it unclear and I'm not trying to undelete anything, I'm just trying to mount this drive which worked perfectly fine before I wiped my laptop when upgrading from Ubuntu 14 to 16. As soon as I was on a new system I started having a problem. Though I've tried and failed with a bunch of solutions from online so it could be that I created all these processes at some point I'm not sure. Either way I thought it was worth opening a new question.)
Update: the command mount responds with:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1943712k,nr_inodes=485928,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=392632k,mode=755)
/dev/sda1 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd,nsroot=/)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,nsroot=/)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory,nsroot=/)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices,nsroot=/)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event,nsroot=/)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct,nsroot=/)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids,nsroot=/)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio,nsroot=/)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio,nsroot=/)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb,nsroot=/)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer,nsroot=/)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=392632k,mode=700,uid=1000,gid=1000)
/home/.ecryptfs/heim/.Private on /home/heim type ecryptfs (rw,nosuid,nodev,relatime,ecryptfs_fnek_sig=8b5e55b44798c614,ecryptfs_sig=bff979ff1961fd73,ecryptfs_cipher=aes,ecryptfs_key_bytes=16,ecryptfs_unlink_sigs)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
