I need to restore some files deleted from pratition.
ben@ben-V5-171:~$ sudo ntfsundelete /dev/sdb1
Access is denied because the NTFS volume is already exclusively opened.
The volume may be already mounted, or another software may use it which
could be identified for example by the help of the 'fuser' command.
You can use force option to avoid this check, but this is not recommended
and may lead to data corruption.
ben@ben-V5-171:~$ fuser /dev/sdb1
ben@ben-V5-171:~$ sudo fuser /dev/sdb1
ben@ben-V5-171:~$ lsof /dev/sdb1
ben@ben-V5-171:~$ sudo lsof /dev/sdb1
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/ben/.gvfs
Output information may be incomplete.
ben@ben-V5-171:~$
