Can I use binaries compiled for Scientific Linux on Ubuntu? I need to use library called ROOT in old version (released in 2010), but can't find binaries for Ubuntu.
No and yes...
No, Scientific Linux is based on Red Hat and they use .rpm-packages; and Ubuntu is based on Debian, so you need .deb-packages.
But you can try to use alien to install/convert foreign packages: https://help.ubuntu.com/community/RPM/AlienHowto
but IMHO compiling it yourself is definitely the better way...!
there were some problems/questions installing root-system in the past, so i link them here (maybe they are helpful):
How do I install root-cern?
Problem trying to install ROOT (by CERN) on 11.04 i386
How to install ROOT cern on Ubuntu 15
maybe also the obviously discontinued project Cern Root debs is worth a look: https://sourceforge.net/projects/cernrootdebs/
but no matter which method you use for installing (or also compiling)... with a 6 years old package/source on an actual system you might get stuck in a dependency hell.
- 1,922
SL use RPM and Ubuntu use Dppkg for package management so is unlikely.
Can you compile from source? Do you know the library dependencies?
- 205
