shinee@shinee:~/Downloads/root$ sudo apt-get install libx11-dev
Reading package lists... Done
Building dependency tree
Package libx11-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libx11-dev' has no installation candidate
Asked
Active
Viewed 1,153 times
Arronical
- 20,241
If you encountered the problem with
configure: c++11 mode is requested but the current compiler does not support it.
while running ./configure linux on a 64bit ubuntu 15.10, this can be solved by installing/updating your gcc and g++ packages:
sudo apt-get update
sudo apt-get install gcc g++
and specifying your architecture in the configure command:
./configure linuxx8664gcc
DominikCZ
- 79
