I'm a new user of ubuntu. It's been working fairly well so far. Today I've tried doing 'sudo apt-get update' and it's freezing after fetching data. This is the output:
sudo apt-get update
Hit:1 http://archive.canonical.com/ubuntu xenial InRelease
Hit:2 http://ppa.launchpad.net/webupd8team/sublime-text-3/ubuntu xenial InRelease
Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [94.5 kB]
Hit:4 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Hit:5 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease
Get:6 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [92.2 kB]
Fetched 187 kB in 0s (225 kB/s)
Using sudo apt-get clean and then sudo apt-get update, I get the following issue:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
Using sudo rm -rf /var/lib/apt/lists/lock and then sudo apt-get update I get a new issue:
** (appstreamcli:3466): WARNING **: Exception: Unable to get write lock on /var/cache/app-info/xapian/default: already locked
sudo fuser /var/cache/app-info/xapian/default
shows nothing.
file /var/cache/app-info/xapian/default
shows
/var/cache/app-info/xapian/default: directory
Tim
  • 33,500
chris
  • 179
Check out this link. I ran into the could not get lock issue the other day and resolved it with the same answer that Faheem Mitha used.
ps aux | grep apt
This will return a list of things that apt is doing with PIDs. Then run:
kill processnumber
or
kill -9 processnumber
You may or may not have to invoke sudo priveleges in order to kill the process depending on your setup.
Yeah,I have the Same Problem, the Solve(I am not Sure it is) of mine is:
  1. Restart the System
  2. killall the relative Process
  3. sudo apt-get upgrade
  4. then you could install normally
  5. Done! It Works.
muru
  • 207,228
A temporary fix for now is to simply delete everything under /var/cache/app-info/xapian/default. It appears to be the search index for apt, so it will have to be rebuilt, but no ill effects otherwise.
