I have recently installed Ubuntu 16.04 and yesterday I've installed Sublime-text-3 text editor. But the main problem is Menu is not showing unless its opened in root mode,i.e sudo /opt/sublime_text/sublime_text I have searched for various solutions in stackoverflow and askubuntu,but neither solution worked as desired. I have referred sublime from launcher but it also not worked. I had installed sublime-text-3 in previous ubuntu versions and also linux-mint which i had used in the past. But no-where this problem occurred.
Can anyone has similar problem OR some working solutions,please share here.
Ankith p
  • 301
I temporary fixed this by adding command to startup applications list:
bash -c "sleep 2 && initctl restart unity-panel-service"
You can also press ALT+F2 and execute:
Ps: This will restart all indicators services and some of them will disappear if they started before.
BaronBaleron
  • 1,136
