12
I've successfully installed Ubuntu 11.10 alongside Windows 7. During installation I've manually changed the Windows partition size ( there were 24Gb used, I've changed virtual partition size from 100Gb to 40Gb) and killed the 150Mb partition where Windows stores system recovery data. I've installed Ubuntu on second virtual partition.
So now when the GRUB starts it cannot see the Windows installer. I think it's all OK with windows loader, just GRUB does not know about it.
So I need to specify it manually. Where and how?
txwikinger
  • 29,406
Dan
  • 533
Run this from Ubuntu:
sudo update-grub
And reboot.
Windows should be in the Grub menu now.
SirCharlo
  • 40,096
edit Grub menu
gksudo gedit /boot/grub/menu.lst
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sdb1
title Windows 7
root (hd1,0)
savedefault
makeactive
map (hd0) (hd1)
map (hd1) (hd0)
chainloader +1
edit /etc/fstab so windows partitions are accesible in linux:
sudo apt-get install ntfs-config
sudo ntfs-config
add mount points in /media for windows partitions
i think this will help you
twister_void
  • 5,934
