I have three partitions on my netbook:
  1. ntfs with windows 7
  2. ext 4 with Ubuntu 11 and
  3. fat32 for my private data
On the fat32-Partition Ubuntu und Windows 7 should share my private data.
How could I move my home directory with the exiting files to the fat32-partition? And how do I mount this partition permanently as my home-directory?
Many thanks for an helpful answer.
Eric Carvalho
  • 55,453
Himmi
  • 23
As per my point of view please understand the merit and demerit of moving home folder to other file system
NTFS is not suitable for an home partition, there are certain type of file system objects (character devices, named pipes, etc) which are required for certain services but are not supported on NTFS. source
It's not a good idea to have the whole of /home in a fat32 or NTFS partition because those two Windows filesystems don't support Linux permissions. Also, the /home folder has many hidden files and folders (these have a leading . i.e for hidden files) for configuration and I don't know what effect this would have in Vista, or whether Vista would interfere with these..
But what I do is to have a separate NTFS partition for data and set up symlinks from my /home in Linux and whatever the equivalent is in Windows (links? shortcuts? ). So - say I have a 'Music' folder in my NTFS data partition, then I create a symlink called 'Music' in my Linux home and a link called - yes, you've guessed it - 'Music' in Windows My Documents. (I'm using XP.) In fact I also multiboot several Linux distros, so I do the same in each. Whichever distro/OS I'm in I can access the same files from my home folder by double-clicking on the symlinks (which look like folders with bendy arrows in Linux)
If I am wrong correct me
twister_void
  • 5,934
-5
Follow these commands
usermod -d /home/your_home_directory USERNAME
chown -R USERNAME /new_location/your_home_directory
coder
  • 3,691
