I'm installing a SSD and to save space I want to move my user folder to another drive, is there a way to do that?
zShell
  • 171
From Terminal type this:
sudo mkdir /mnt/tmp
sudo mount /dev/sdb1 /mnt/tmp
which will allow you to temporarily mount the new partition, assuming /sdb1 as new partition for HOME.
sudo rsync -avx /home/ /mnt/tmp
This will copy HOME to new location.
sudo mount /dev/sdb1 /home
This will mount the new partition as HOME and make sure all data is present.
sudo umount /home
This will unmount the new partion.
rm -rf /home/*
This deletes the old HOME.
To make HOME permanent you need to know the UUID of the new partition for the fstab entry. you can get that by giving command:
sudo blkid
Note down the UUID and use the same to change fstab .
sudo nano /etc/fstab
Now add the following at the end.
UUID=<noted number from above>    /home    ext4    defaults   0  2
NOTE: You need to select the exact file system that was formatted (for example ext4 as chosen here).
Now you can restart your computer to see the new HOME.
UkFLSUI
  • 103
VRU
  • 1,143
Copy all the files from your /home to another drive
Change the /etc/fstab entry to point /home to that drive
If you don't how, reply. I will provide a shell script to do that.
blvdeer
  • 482
