I have a laptop hooked up to a TV via HDMI. When the TV powers off, the audio output switches from HDMI to the built-in laptop speakers. This behaviour is new, as previous Ubuntu versions would always stay on the last device I chose (HDMI.) How can I control this feature so as to always have HDMI selected even when the TV is off?
Failing that, how can I disable the built-in laptop speakers so they are never available, hopefully forcing the audio output to HDMI?
So it turns out everything you think you're editing in /etc/pulse/default.pa file isn't doing squat until you copy it to your current user profile (~/.config/pulse/) Shout out to Nebuzaradan for discovering the solution: https://unix.stackexchange.com/questions/293399/how-to-set-hdmi-sound-output-as-default-on-ubuntu-16-04
You can use pavucontrol (Pulseaudio volume control, install if necessary):
Launch it from multimedia menu, go to the "output devices" tab, and click the green "define as alternative" button that is near HDMI soundcard.
Look also "configuration" tab: you will find various profile such as HDMI .
laugeo
  • 2,880
  • 14
