You can do that in the following setup, which will produce a semi- transparent window, staying for an arbitrary time:
Create in a (any) directory, in which each of the users at least has read permissions, for each user a message file, exactly named after each user's username (log in name), no extension, e.g.
jacob
Add text to the file as your message. If you add a new message, start with ###, the script will then automatically display the last message. The text can contain anything you like, it will look exactly like you put it in the file.
The latest message, will be copied as latest_message.txt to the user's home directory for reference.
As it is, the window will stay for 15 seconds, but you can set it to any value, even make it automatically depend on the length of the text.
An example file could look like:
Vraag:
Een aap op een fiets, hoe vind je zoiets?
Opdracht:
Geef antwoord op de vraag!
Vraag:
Hoe is de koffie vandaag?
Opdracht:
Zet het zelf even als het niet te drinken is!
The message then would look like:
Copy the script below into an empty file, edit in the head section of your script the path to the folder in which you store the user(s) messages. Save the script as show_personalmessage in (e.g.) /usr/local/bin (which should be in $PATH and make it executable(!) (no extension)
#!/usr/bin/env python3
import subprocess
import os
import gi
gi.require_version('Gtk', '3.0')
from gi.repository import GObject, Gtk, Gdk, Pango
from threading import Thread
import time
import getpass
# --- set the path to the message files below, filename = username
filedir = "/home/jacob/Bureaublad"
# --- set the time to show the window below
showtime = 15
# don't change anything below
user = getpass.getuser()
currmessage = os.environ["HOME"]+"/latest_message.txt"
f = filedir+"/"+user
text = "Welcome "+user+"\n\n"+open(f).read().split("###")[-1]
open(currmessage, "wt").write(text)
class Splash(Gtk.Window):
def __init__(self):
Gtk.Window.__init__(self, title="splashtitle")
maingrid = Gtk.Grid()
self.add(maingrid)
maingrid.set_border_width(80)
# set text for the spash window
label = Gtk.Label(text)
label.modify_font(Pango.FontDescription('Ubuntu 12'))
maingrid.attach(label, 0, 0, 1, 1)
self.stop = Thread(target=self.close_window)
self.stop.start()
def close_window(self):
time.sleep(showtime)
Gtk.main_quit()
def splashwindow():
window = Splash()
window.set_decorated(False)
window.set_resizable(False)
window.override_background_color(Gtk.StateType.NORMAL, Gdk.RGBA(0,0,0,1))
window.modify_fg(Gtk.StateFlags.NORMAL, Gdk.color_parse("grey"))
window.set_opacity(0.8)
window.set_position(Gtk.WindowPosition.CENTER)
window.show_all()
GObject.threads_init()
Gtk.main()
splashwindow()
Create a launcher in /etc/xdg/autostart
[Desktop Entry]
Type=Application
Name=Splash
Exec=/bin/bash -c "sleep 10 && show_personalmessage"
The sleep 10 is to make sure the desktop is "ready" to open the window.
Explanation
- Launchers in
/etc/xdg/autostart run commands for each user on log in.
- The launcher then runs the window (called by the command
show_personalmessage), which looks for the personalized message in the directory you defined. Additionally. The most recent message is copied to the user's home directory.
- If required, the path to the message can be altered, even be made user specific by using the
getpass -module, so that the script (window) will look for a user- specific named file in a directory. Please mention if that would be required.
Additionally
The (Gtk) window
- can be made to stay below everything, as if it would be part of the background
- can be made stay on top of everything
- can be made closeable
etc, etc...
EDIT
To save time writing messages, as discussed in chat, below a version of the script in which you can include a few "permanent" sections:
premsg, which should be just below "Welcome user x", and the body of your message, and
postmsg, which comes as the bottom section of your message.
Both sections can be set to none, just by setting "" as a value.
The script
import subprocess
import os
import gi
import time
import getpass
filedir = "/path/to/message_directory"
showtime = 15
# --- set pre-message below. set premessage = "" for no pre-message
premsg = """We assume you read all 3782 instruction pages on how to use
Ubuntu before you push any button on this computer.
# --- set post-message below. set postmessage = "" for no post-message
postmsg = """Before you go to sleep tonight, make sure to brush your
teeth for at least half an hour
# --- don't change anything below
text = "Welcome "+user+"\n\n"+premsg+"\n"+open(f).read().split("###")[-1]+"\n"+postmsg
def __init__(self):
self.add(maingrid)
self.stop.start()
Gtk.main_quit()
def splashwindow():
window = Splash()
window.modify_fg(Gtk.StateFlags.NORMAL, Gdk.color_parse("white"))
window.show_all()
Gtk.main()
splashwindow()
Note
Of course, just like the message body, yoy can alter the script to read the pre- and post messages from a file, which makes it even more convenient to maintain. Did it like this, for reasons of simplicity in the answer.
