I am trying to run php with netbeans, when i try to run it, the echo in php is not comming in the browser, but the html file is working
My code
<html>
<head>
    <meta charset="UTF-8">
    <title></title>
</head>
<body>jjjjjj
    <?php
    echo 'hello world';
</body>
</html>
Only the jjjjjj is comming.
When i give php -v in terminal this is comming
PHP 7.0.4-7ubuntu2 (cli) ( NTS )
Copyright (c) 1997-2016 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2016 Zend Technologies
with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
and i searched for php problem and tried to install php but
sudo apt-get install apache2 php5 libapache2-mod-php5
Reading package lists... Done
Building dependency tree
apache2 is already the newest version (2.4.18-2ubuntu3).
php5 is already the newest version (5.3.2-1ubuntu4).
 dbus : Depends: adduser but it is not going to be installed
 dpkg : Breaks: libapache2-mod-php5 (< 5.6.4+dfsg-3~) but 5.3.2-1ubuntu4 is to be installed
 libapache2-mod-php5 : Depends: apache2-mpm-prefork (> 2.0.52) but it is not going to be installed or
                                apache2-mpm-itk but it is not installable
                       Depends: apache2.2-common but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
the problem is with php7 or php5?
Please help me
Mukund
  • 905
From your log, it looks like an older version of package (which maybe unofficial ) is causing issue during installation.
The answer to your question is well explained with the solution here : askubuntu: libapache-mod5-php- installation issue
Follow the solution there. If problem exists please comment.
ankit7540
  • 4,195
