I installed php5.5 and upgrade Ubuntu from 12 to 14. Now the system isn't working. I did
sudo apt-get upgrade && sudo apt-get install libapache2-mod-php5
But got
 libapache2-mod-php5 : Depends: php5-common (= 5.5.9+dfsg-1ubuntu4.4) but 5.5.18+dfsg-1+deb.sury.org~precise+1 is to be installed
How do I resolve it?
The commands I used to install php5.5 were like:
add-apt-repository ppa:ondrej/php5-oldstable
apt-get install ppa:ondrej/php5-oldstable
apt-get update
apt-get install php5
apt-get install python-software-properties
apt-get update
apt-get install php5-common php5-mysql php5-xmlrpc php5-cgi php5-curl php5-gd php5-cli php5-fpm php-apc php-pear php5-dev php5-imap php5-mcrypt
αғsнιη
  • 36,350
heya
  • 63
Your problem is that you have an unofficial PPA which is breaking your install procedure. To remediate this, run the below commands:
sudo add-apt-repository --remove ppa:ondrej/php5-oldstable
This PPA is providing a different (old) version of PHP instead of the proper version that Ubuntu wants.
Run these commands to add the extra repositories:
sudo add-apt-repository universe
sudo add-apt-repository multiverse
Now, run:
sudo apt-get update
Your repository information will be the official Ubuntu ones. Install libapache2-mod-php5 using this command:
Note: You may need to uninstall the old PHP packages first. Command:
sudo apt-get remove php5 php5-common php5-mysql php5-xmlrpc php5-cgi php5-curl php5-gd php5-cli php5-fpm php-apc php-pear php5-dev php5-imap php5-mcrypt
You should not add PPAs unless you absolutely need them. They can break more than they solve and can cause problems like this. Also, unofficial PPAs are attack vectors for potential viruses. Unless you really need to use a PPA, don't.
Kaz Wolfe
  • 34,680
