I have never used Ubuntu or any other Linux OS before last Friday. For all I know, I might have installed Ubuntu wrong and be missing a component. I would prefer if you use simplest terminology possible, but I'm OK with doing a bit of googling if need be. I just installed Steam for Ubuntu 16.04 but it won't open when I click on it in the launcher. The icon flashes for a few seconds, stops and then nothing happens. I looked in the system monitor and steam shows up there but ending the process and trying again does nothing. I heard trying to open apps that aren't working through the terminal tells you what the error is so I tried that and I got this:
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(0)
libGL error: unable to load driver: radeonsi_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: radeonsi
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Please help I just want to play CS:GO again.
