Whenever I click the steam app it won't start and when I try from the terminal it says:
Running Steam on ubuntu 15.10 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(0)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
What do I do?
Zanna
  • 72,312
seems to be a Problem with the libs from Steam. Here is a link which discribe the problem link . You can try to delete the file like suggested there.
Alternativly you can try start steam without this libs with adding STEAM_RUNTIME=0. You can test this if you start a terminal and start steam with this like
STEAM_RUNTIME=0 steam
Regards, Kai
Kais3n
  • 56
