Here are the steps
  1. sudo apt-get install software-properties-common
  2. sudo apt-key adv --recv-keys --keyserver hkp://keyserver.ubuntu.com:80 0xF1656F24C74CD1D8
  3. $ sudo add-apt-repository 'deb [arch=amd64,i386] http://mirror.fibergrid.in/mariadbrepo/10.1/ubuntu xenial main'
  4. sudo apt-get update
  5. sudo apt-get install mariadb-server
Error
sudo: /etc/sudoers.d is world writable
Reading package lists... Done
Building dependency tree
 mariadb-server : Depends: mariadb-server-10.1 (= 10.1.14+maria-1~trusty) but it is not going to be installed
Anwar
  • 77,855
8 Answers8
Please check that Apache and php packages exist or not in your machine.
Please follow this steps to completely remove MySQL
Now open the terminal Ctrl + T
sudo apt-get purge mysql-server mysql-client mysql-common mysql-server-core-5.5 mysql-client-core-5.5
sudo rm -rf /etc/mysql /var/lib/mysql
sudo apt-get autoremove
sudo apt-get autoclean
Install apache
sudo apt-get install apache2
Install php
sudo apt-get install libapache2-mod-php mysql-server mysql-client
sudo mysql_install_db
sudo mysql_secure_installation
Now open mysql in terminal
mysql -u root -p
Please note the version of php. ref reason why php 7
Their is one way to install php 5 by adding ppa If you want version 5 php.
sudo add-apt-repository ppa:ondrej/php
sudo apt-get update
sudo apt-get install php5.6
Other Ref : php version issue
Thanks Ajay
In my case, the ibdata1 file was corrupt. I fixed as follows:
$ sudo apt-get purge mariadb-*
$ sudo rm -f /var/lib/mysql/ib*
$ sudo apt-get install mariadb-server
If you installed MariaDB/MySQL server before, remove them first:
sudo apt-get remove mariadb-server mariadb-client mysql-server mysql-client
Then make sure no mysqld process is running.
sudo kill -9 $(pgrep mysql)
After that, install MariaDB server. if you still see the same error, you should check out MariaDB error log /var/log/mysql/error.log to find out the cause.
source: linuxbabe.com - install MariaDB 10.1 on Ubuntu 14.04 and 16.04
LinuxBabe
  • 205
I got the same error, but it turned out to be because I had installed std mysql and had uninstalled it. The cure was deleting the /var/lib/mysql directory and running the mariadb install again.
Andy
Mariadb is available in official Ubuntu repositories so no need to enable third-party repositories. Ubuntu has official repositories called main, universe & multiverse. Most likely your installation has only main enabled. You can enable universe with How do I enable the "Universe" repository?
sudo add-apt-repository universe
tinlyx
  • 3,328
Dennis
I am using Ubuntu 18.04 and got the same error when I wanted to install mariadb. The one solution above worked for me, although the were some error messages about old packages.
sudo add-apt-repository 'deb [arch=amd64,i386] http://mirrors.hustunique.com/mariadb/repo/10.1/ubuntu xenial main'
Followed by:
sudo apt-get update
Eliah Kagan
  • 119,640
To install MariaDB you need to use the right installation file on Ubuntu
sudo apt-get install mariadb-server-core-10.1
Here are the commands to run to install MariaDB on your Ubuntu system:
Once the key is imported and the repository added you can install MariaDB with:
sudo apt-get update
Eofla
  • 189
