Ubuntu Unity 16.04 Toshiba Chromebook 2
I'm trying to get my mic working, either external or internal.
There is no input sound available within settings and no internal external mic option within alsamixer capture panel, only within the playback panel.
There is no feedback within pavucontrol and I've completely come to a dead end to fix it.
Any help would be great.
saph_top
  • 166
According to https://bugs.launchpad.net/ubuntu/+source/alsa-driver/+bug/1420988, you should add the line options snd-hda-intel model=dell-headset-multi in the file called /etc/modprobe.d/alsa-base.conf (or create the file if it doen't exist). You might need to adjust your model. I have seen model=intel a lot. https://ubuntuforums.org/showthread.php?t=1043568 and https://docs.slackware.com/howtos:hardware:audio_and_snd-hda-intel can help you out.
Did the trick for me partly. Also, hdajackretask is your friend: I needed to set Pin 0x18 to microphone. Or, via ->advanced, to headphones (thus the contact works for both)
For configuration, the standard pavucontrol and gnome-alsa-mixer will be helpful.
phil294
  • 639
