Possible Duplicate:
How do I install gcc-4.3?
How can I compile (or just install) gcc 4.3.4 on my Ubuntu 11.10 ?
I've tried to download and compile it with these instructions: http://whowhywhathow.blogspot.com/2011/01/compile-gcc-from-souce-on-ubuntu-10041.html
But it just end up with an error during the compilation:
http://pastebin.ca/2092965
Hope someone here can help me
I think this should install everything you need, and a few other bits besides.
apt-get build-dep gcc-4.6
You might find that some of the tools are too new to build gcc 4.3 though (autoconf, automake, perhaps?) but I doubt there's any packages for that old stuff anyway.
ams
  • 3,089
Hey GCC requires a number of other softwares for installation such as bison etc. First please make sure if you got got all the required softwares pre installed.
coder
  • 3,691
There is definitely no need to use gcc-4.3.
Of course you always get the warning message during mex-files creating:
Warning: You are using gcc version "4.6.x.x)". The version currently supported with MEX is "4.3.4". For a list of currently supported compilers see: http://www.mathworks.com/support/compilers/current_release/
but this is a warning - the MEX function will still compile!!!
The only thing to change is new link on libc.so.6 library
So for 64 bit: Remove old link
sudo rm /lib64/libc.so.6
(Be careful when removing the old link. It is essential for Linux to boot. So if you reboot before replacing the link with the new version then it'll be time to dig out a live disk. If you're paranoid then you can copy libc.so.6 to something like libc.so.6.backup first
cp /lib64/libc.so.6 /lib64/libc.so.6.backup
Replace with new link
sudo ln -s /lib/x86_64-linux-gnu/libc-2.13.so /lib64/libc.so.6
For 32 bit: (I have not tested this as I only run x64 systems, but from the comments I think it should work)
Remove old link (again be careful with this command)
sudo rm /lib32/libc.so.6
sudo ln -s /lib/i386-linux-gnu/libc-2.13.so /lib/libc.so.6
Of course if this is a fresh Ubuntu install then you probably wont need the rm (remove) command.
Bruno Pereira
  • 74,715
The relevant error is ../../.././mpfr/src/mulders.c:208:3: error: unknown type name 'gmp_pi1_t'. I'd guess you don't have the GMP development libraries installed.
Why do you need gcc 4.3.4 again? Anyway, the simplest thing to do would be to download Ubuntu sources for 4.3.4 (if necessary from an earlier version of Ubuntu) and rebuild on your system, making sure you have the build dependencies installed first, naturally. This should be straightforward to do.
I can add more details if you need them.
Faheem Mitha
  • 7,871
