Is there and easy way to install gcc-4.3 on Oneiric ? I really need it because matlab depends on i for the creation of mex-files
I tried changing all my resopistories back to Maverick just to install gcc-4.3 but I get this error:
refl_v0p8_linux_and_windows % sudo apt-get install gcc-4.3-multilib libstdc++6-4.3-        dev
Reading package lists... Done
Building dependency tree
 gcc-4.3-multilib : Depends: gcc-4.3 (= 4.3.5-3ubuntu1) but it is not going to be     installed
                Depends: libc6-dev-i386 (>= 2.5) but it is not going to be installed
 libstdc++6-4.3-dev : Depends: g++-4.3 (= 4.3.5-3ubuntu1) but it is not going to be         installed
    E: Broken packages
Jorge Castro
  • 73,717
5 Answers5
1) Edit the sources.list file:
sudo gedit /etc/apt/sources.list
add this line:
deb http://mirror.pnl.gov/ubuntu/ hardy-updates main universe
a complete list of mirror sites are given here
Save and close the file
2) Logout the login
3) Open Synaptic. If you don't see the mirror.pnl.gov/ubuntu/ hardy-updates main universe in the source-list on the left, click on Reload.
4) Choose mirror.pnl.gov/ubuntu/ hardy-updates main universe from the left column - this should show the list of packages.
5) Choose g77 from the list, mark for installation and apply. g77 is now installed and is ready to use.
Peachy
  • 7,235
  • 40
  • 47
There is definitely no need to use gcc-4.3. Of course you always get the warning message during mex-files creating:
Warning: You are using gcc version "4.6.x.x)". The version currently supported with MEX is "4.3.4". For a list of currently supported compilers see: http://www.mathworks.com/support/compilers/current_release/
but this is a warning - the MEX function will still compile!!!
The only thing to change is new link on libc.so.6 library: (see http://morganbye.net/blog/2011/10/matlab-ubuntu-1110)
So for 64 bit: Remove old link
sudo rm /lib64/libc.so.6
(Be careful when removing the old link. It is essential for Linux to boot. So if you reboot before replacing the link with the new version then it'll be time to dig out a live disk. If you're paranoid then you can copy "cp" libc.so.6 to something like libc.so.6.backup first.)
Replace with new link
sudo ln -s /lib/x86_64-linux-gnu/libc-2.13.so /lib64/libc.so.6
For 32 bit: (I have not tested this as I only run x64 systems, but from the comments I think it should work)
Remove old link (again be careful with this command)
sudo rm /lib32/libc.so.6
sudo ln -s /lib/i386-linux-gnu/libc-2.13.so /lib/libc.so.6
Of course if this is a fresh Ubuntu install then you probably wont need the rm (remove) command.
Jorge Castro
  • 73,717
I know this question is two years old, but I don't like to see questions that never get an accepted answer so I'm trying to help.
This doesn't use the package manager, but at http://gcc-uk.internet.bs/releases/ you can find almost every version of GCC. Version 4.3.0 (and likely all others) include HTML installation instructions. If you don't like UK servers, there is a list of mirrors at the GCC website; some of them might have old versions like this one does.
I have to disagree with Michal Kvasnicka, you should always use the specified version of GCC.
Wutaz
  • 541
You have broken dependencies. You can "repair" them doing
sudo apt-get -f install
But before saying yes, please look, what apt tries to uninstall.
And as a hint: It is not a good idea to downgrade the ubuntu verion just to get another version of gcc. You can have multiple versions of gcc on one machine! I would go again to the version you had before your failed attempt to downgrade and keep the gcc version you had before. Then get the tar-ball of gcc 4.3 and compile it yourself, it is not difficult. After that you have two gcc versions, then you can point matlab to the other version (specify the gcc path somewhere in matlab).
It would not recommend you to compile other software with a gcc version other than the one that was installed by default in ubuntu.
Michael K
  • 14,338
Possible workaround: (fix for MATLAB, not GCC-4.3)
from: http://xcorr.net/2010/05/07/getting-gcc-to-work-with-matlab-r2009b-on-linux-ubuntu-karmic-to-compile-mex-files/
(in summary)
Step 1:
for MATLAB, with sudo run mex -setup and select the (latest) GCC compiler.
Step 2:
sudo gedit ~/.matlab/R2009b/mexopts.sh
Replace ALL instances of CC=’gcc’ with CC=’gcc-4.6′
(optional) Replace -ansi with -std=c99, to allow use of C++ style // comments.
Note: If you later re-run mex -setup, this will overwrite the mexopts.sh file.
david6
  • 14,528
  • 38
  • 46
