I am receiving this error again and again. At the end, getting it has already installed. Please suggest how I can fix this. I tried all solutions mentioned on this question but got no solution.
vinayak@vinayak-PC:~$ sudo apt-get install libopencv-highgui-dev
Reading package lists... Done
Building dependency tree
libopencv-highgui-dev : Depends: libgtk2.0-dev but it is not going to be installed
Depends: libraw1394-dev but it is not going to be installed
Depends: libdc1394-22-dev but it is not going to be installed
vinayak@vinayak-PC:~$ sudo apt-get install libgtk2.0-dev
libgtk2.0-dev : Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
Depends: libxinerama-dev (>= 1:1.0.1-4.1) but it is not going to be installed
Depends: libxi-dev (>= 1:1.0.1-4) but it is not going to be installed
Depends: libxrandr-dev (>= 2:1.2.99) but it is not going to be installed
Depends: libxcursor-dev but it is not going to be installed
vinayak@vinayak-PC:~$ sudo apt-get install libpango1.0-dev
libpango1.0-dev : Depends: libpango-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is to be installed
Depends: libpangocairo-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is to be installed
Depends: libpangoft2-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is to be installed
Depends: libpangoxft-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is to be installed
Depends: libfreetype6-dev but it is not going to be installed
Depends: libxrender-dev but it is not going to be installed
Depends: libxft-dev but it is not going to be installed
Depends: libfontconfig1-dev (>= 2.10.91) but it is not going to be installed
Depends: libharfbuzz-dev (>= 0.9.9) but it is not going to be installed
Depends: libcairo2-dev (>= 1.12.10) but it is not going to be installed
Recommends: debhelper but it is not going to be installed
vinayak@vinayak-PC:~$ sudo apt-get install libpango-1.0-0
libpango-1.0-0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
On performing aptitude install, I received this
vinayak@vinayak-PC:~$ sudo aptitude install libopencv-dev
The following NEW packages will be installed:
gir1.2-gtk-2.0{a} libatk1.0-dev{a} libavcodec-dev{a} libavformat-dev{a}
libavutil-dev{a} libcairo-script-interpreter2{a} libcairo2-dev{ab}
libcv-dev{a} libcvaux-dev{a} libdc1394-22-dev{a} libfontconfig1-dev{ab}
libfreetype6-dev{ab} libgdk-pixbuf2.0-dev{a} libgtk2.0-dev{a}
libharfbuzz-dev{ab} libharfbuzz-gobject0{a} libhighgui-dev{a}
libilmbase-dev{a} libjasper-dev{a} libopencv-calib3d-dev{a}
libopencv-contrib-dev{a} libopencv-core-dev{a} libopencv-dev
libopencv-features2d-dev{a} libopencv-flann-dev{a} libopencv-gpu-dev{a}
libopencv-gpu2.4{a} libopencv-highgui-dev{a} libopencv-imgproc-dev{a}
libopencv-legacy-dev{a} libopencv-ml-dev{a} libopencv-objdetect-dev{a}
libopencv-ocl-dev{a} libopencv-ocl2.4{a} libopencv-photo-dev{a}
libopencv-stitching-dev{a} libopencv-stitching2.4{a}
libopencv-superres-dev{a} libopencv-superres2.4{a} libopencv-ts-dev{a}
libopencv-ts2.4{a} libopencv-video-dev{a} libopencv-videostab-dev{a}
libopencv-videostab2.4{a} libopencv2.4-java{a} libopencv2.4-jni{a}
libopenexr-dev{a} libpango1.0-dev{ab} libpixman-1-dev{ab}
libraw1394-dev{ab} libraw1394-tools{ab} libswscale-dev{a}
libxcb-shm0-dev{ab} libxcomposite-dev{a} libxcursor-dev{ab}
libxft-dev{ab} libxi-dev{ab} libxinerama-dev{ab} libxrandr-dev{a}
libxrender-dev{ab} opencv-data{a} x11proto-composite-dev{a}
x11proto-randr-dev{a} x11proto-render-dev{a} x11proto-xinerama-dev{a}
0 packages upgraded, 65 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.5 MB of archives. After unpacking 112 MB will be used.
libpixman-1-dev : Depends: libpixman-1-0 (= 0.30.2-2ubuntu1.1) but 0.33.6-1 is installed.
libfreetype6-dev : Depends: libfreetype6 (= 2.5.2-1ubuntu2.5) but 2.6.3-3 is installed.
libpango1.0-dev : Depends: libpango-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is installed.
Depends: libpangocairo-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is installed.
Depends: libpangoft2-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is installed.
Depends: libpangoxft-1.0-0 (= 1.36.3-1ubuntu1.1) but 1.38.1-1 is installed.
libraw1394-dev : Depends: libraw1394-11 (= 2.1.0-1ubuntu1) but 2.1.1-2 is installed.
libxcb-shm0-dev : Depends: libxcb-shm0 (= 1.10-2ubuntu1) but 1.11.1-1 is installed.
libxi-dev : Depends: libxi6 (= 2:1.7.1.901-1ubuntu1.1) but 2:1.7.6-1 is installed.
libraw1394-tools : Depends: libraw1394-11 (= 2.1.0-1ubuntu1) but 2.1.1-2 is installed.
libcairo2-dev : Depends: libcairo2 (= 1.13.0~20140204-0ubuntu1.1) but 1.14.6-1 is installed.
Depends: libcairo-gobject2 (= 1.13.0~20140204-0ubuntu1.1) but 1.14.6-1 is installed.
libxft-dev : Depends: libxft2 (= 2.3.1-2) but 2.3.2-1 is installed.
libxrender-dev : Depends: libxrender1 (= 1:0.9.8-1build0.14.04.1) but 1:0.9.9-2 is installed.
libxinerama-dev : Depends: libxinerama1 (= 2:1.1.3-1) but 2:1.1.3-1+b1 is installed.
libharfbuzz-dev : Depends: libharfbuzz0b (= 0.9.27-1ubuntu1) but 1.0.1-1+b1 is installed.
libfontconfig1-dev : Depends: libfontconfig1 (= 2.11.0-0ubuntu4.1) but 2.11.0-6.3 is installed.
libxcursor-dev : Depends: libxcursor1 (= 1:1.1.14-1) but 1:1.1.14-1+b1 is installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) libcairo2-dev [Not Installed]
2) libcv-dev [Not Installed]
3) libcvaux-dev [Not Installed]
4) libdc1394-22-dev [Not Installed]
5) libfontconfig1-dev [Not Installed]
6) libfreetype6-dev [Not Installed]
7) libgtk2.0-dev [Not Installed]
8) libharfbuzz-dev [Not Installed]
9) libhighgui-dev [Not Installed]
10) libopencv-contrib-dev [Not Installed]
11) libopencv-dev [Not Installed]
12) libopencv-highgui-dev [Not Installed]
13) libopencv-legacy-dev [Not Installed]
14) libopencv-objdetect-dev [Not Installed]
15) libopencv-ocl-dev [Not Installed]
16) libopencv-superres-dev [Not Installed]
17) libopencv-videostab-dev [Not Installed]
18) libpango1.0-dev [Not Installed]
19) libpixman-1-dev [Not Installed]
20) libraw1394-dev [Not Installed]
21) libraw1394-tools [Not Installed]
22) libxcb-shm0-dev [Not Installed]
23) libxcursor-dev [Not Installed]
24) libxft-dev [Not Installed]
25) libxi-dev [Not Installed]
26) libxinerama-dev [Not Installed]
27) libxrandr-dev [Not Installed]
28) libxrender-dev [Not Installed]
Accept this solution? [Y/n/q/?]
Edit:
I have tried apt-get -f install. It does not work as well.
On lsb_release -a, it gives
➜ ~ git:(master) ✗ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.4 LTS
Release: 14.04
Codename: trusty
