Possible Duplicate:
How can I improve overall system performance?
I have a i3 laptop with Ubuntu 11.10(64bit) and the boot last 30-40 seconds.... how can I make it faster? Also my laptop is just 5-6 mounths and my battery last only 2h 2h 20min with jupiter and the brightness at the minimum level can anyone help?
Orestis
  • 29
Install "powertop" (which you may find in the Ubuntu Software Centre.
It is a command-line utility, which you may find difficult to use, but if you find some tutorials, you could tweak things in your hardware to expend less battery charge.
In my case, I improved from 1:30 hours of charge at common use (surfing the web, mid-brightness), up to 2:20 hours of charge.
Good luck ;)
If you want to extend the battery life, try the recommendations in the following Wiki
https://wiki.ubuntu.com/Kernel/PowerManagement/PowerSavingTweaks
Try out lubuntu, faster boot up time and less CPU intensive, lengthening battery life and shortening boot time. See lubuntu.org for more information.
William
  • 7,720
