I just noticed that if a insert a CD or a DVD of any kind, the Drive will start spinning but it will not show the mounted disc. Earlier it used to ask me what to do with the media inserted. Now it doesn't even do that. I ran the following commands in terminal:
$ eject -n
eject: device is `/dev/sr0'
$ sudo mount -o ro,unhide,uid=1000 /dev/cdrom /mnt/cdrom
mount: mount point /mnt/cdrom does not exist
What can I do to get the functionality back on my drive? I am running Ubuntu 11.10.
Updates
thanks Waltinator: I ran the 'dmesg' but don't know what I'm looking for. Im a newbie on this. The same thing with the 'ls -rlt /var/log' command. Should I create the directory for the mount? at this point really don't know what to do. – Cisco Sán 7 hours ago
After I successfully inserted a CD, following are the first 3 lines of
dmesgcommand:$ dmesg [ 4804.416018] wlan0: no IPv6 routers present [ 8214.125450] ISdit ISO 9660 Extensions: Microsoft Joliet Level 3 [ 8214.136556] ISO 9660 Extensions: RRIP_1991AReply by Waltinator:
The first line is a previous event, my wireless going online. The next 2 lines are a good result. The number in square brackets is "seconds since boot", the rest of the line is usually helpful. And no, you should NOT create the mount point. Let's try to get the automatic mounting to work. – waltinator
These are my last 3 lines of
dmesg:[ 18.130819] init: plymouth-stop pre-start process (1396) terminated with status 1 [ 28.780011] wlan0: no IPv6 routers present [ 505.632119] CE: hpet increased min_delta_ns to 20113 nsecReply by waltinator:
It looks like your CD/DVD drive is not connected to the data bus, and not causing an interrupt when you insert a platter. Try
dmesg | grep -A8 CD-ROMwhich should show you what the system thought was available when it came up. – waltinatorThis is my terminal output:
$ dmesg | grep -A8 CD-ROM [0.774351] scsi 0:0:0:0: CD-ROM HL-DT-ST DVD+-RW GSA-T40N A100 PQ: 0 ANSI: 5 [0.778117] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray [0.778122] cdrom: Uniform CD-ROM driver Revision: 3.20 [0.778282] sr 0:0:0:0: Attached scsi CD-ROM sr0 [0.778340] sr 0:0:0:0: Attached scsi generic sg0 type 5 [0.780416] Freeing unused kernel memory: 984k freed [0.780732] Write protecting the kernel read-only data: 10240k [0.780986] Freeing unused kernel memory: 20k freed [0.786331] Freeing unused kernel memory: 1400k freed [0.804912] udevd[90]: starting version 173 [0.874178] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [0.874208] r8169 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16Reply by waltinator:
OK, your system sees the drive. Can you open and close the tray with
ejectandeject -t? Runudevadm monitorwhile you insert a CD (type ^C when done) and see if you get "change" and "add" messages. – waltinatorejectworks perfectly;eject -tdoes nothing.$ udevadm monitor KERNEL[13771.009267] change /devices/pci0000:00/0000:00:1f.1/host0/target0:0:0/0:0:0:0/block/sr0 (block) UDEV [13773.878887] change /devices/pci0000:00/0000:00:1f.1/host0/target0:0:0/0:0:0 /block/sr0 (block)Terminal output of
sudo hwinfo --cdrom:$ sudo hwinfo --cdrom hal.1: read hal dataprocess 2753: arguments to dbus_move_error() were incorrect, assertion "(dest) == NULL || !dbus_error_is_set ((dest))" failed in file ../../dbus/dbus-errors.c line 280. This is normally a bug in some application using the D-Bus library. libhal.c 3483 : Error unsubscribing to signals, error=The name org.freedesktop.Hal was not provided by any .service files 22: SCSI 00.0: 10602 CD-ROM (DVD) [Created at block.247] Unique ID: KD9E.JgkxTS4hgl2 Parent ID: 3p2J.gdUMCD83e+E SysFS ID: /class/block/sr0 SysFS BusID: 0:0:0:0 SysFS Device Link: /devices/pci0000:00/0000:00:1f.1/host0/target0:0:0/0:0:0:0 Hardware Class: cdrom Model: "HL-DT-ST DVD+-RW GSA-T40N" Vendor: "HL-DT-ST" Device: "DVD+-RW GSA-T40N" Revision: "A100" Driver: "ata_piix", "sr" Driver Modules: "ata_piix" Device File: /dev/sr0 (/dev/sg0) Device Files: /dev/sr0, /dev/scd0, /dev/disk/by-id/ata-HL-DT-ST_DVD+_-RW_GSA-T40N_K048BJ74257, /dev/disk/by-path/pci-0000:00:1f.1-scsi-0:0:0:0, /dev/cdrom, /dev/cdrw, /dev/dvd, /dev/dvdrw Device Number: block 11:0 (char 21:0) Features: DVD Config Status: cfg=new, avail=yes, need=no, active=unknown Attached to: #17 (IDE interface) Drive Speed: 31 Volume ID: "Movie" Publisher: "INTERVIDEO" Creation date: "20050424162207000"
