I have an issue with my laptop's CD tray : whenever I put a CD inside, it rotates and then stops following the same cycles for like 5 minutes during which none of the CD related commands and tools respond.
Then it stops spinning but if I try to read it, the same thing happens again.
Here are the commands I've tried and their outputs ( it might not be exact, I'm translating from french) :
$ eject
Doesn't respond, I can't even cancel with ctrl + c
$ eject -v
eject: use default peripheral 'cdrom'
eject: peripheral's name is 'cdrom'
eject: extended peripheral name is '/dev/cdrom'
eject: '/dev/cdrom' is a link of '/dev/sr0'
eject: '/dev/sr0' isn't mounted
eject: '/dev/sr0' isn't a mounting point
eject: '/dev/sr0' isn't a partitionned peripheral
and after the 5 minutes, when it finally ejects, I get :
eject: attempting to eject '/dev/sr0' with the CD-ROM's ejection command
eject: the CD-ROM's ejection command didn't succeed.
eject: attempting to eject 'dev/sr0' with the SCSI command
eject: the SCSI ejection command succeeded
I also tried lshw : when the tray is not responding the command gets stuck at "SCSI" but after the 5 minutes, I get :
*-scsi
hardware ID: 2
logic name: scsi2
features: emulated
*-cdrom
description: DVD-RAM writer
product: DVDRAM GT51N
manufacturer: HL-DT-ST
hardware id: 0.0.0
information bus: scsi@2:0.0.0
logic name: /dev/cdrom
logic name: /dev/cdrw
logic name: /dev/dvd
logic name: /dev/dvdrw
logic name: /dev/sr0
version: AS00
features: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=ready
*-medium
hardware id: 0
I tried some solutions that I found online, such as this but nothing worked...
Could it be a hardware problem? Is there a way to be sure?
