Bluetooth just absolutely refuses to connect to any audio sinks. I've tried with two separate speakers that I can pair with just fine on iOS, yet when I try, I get this error in blueman:
Connection Failed: DBusFailedError: Protocol not available...
It doesn't even show up in pulseaudio (probably because I can't connect).
I've googled and come across tons of "solutions" that never work. I've honestly tried so many, I forget what I've even tried.
This is important to me because I set up Ubuntu for the purpose of having a HTPC, yet it's lacking functionality to connect with Bluetooth speakers. Any help would be greatly appreciated.
tayoung
  • 171
In my case, this was solved by using these two commands:
pactl load-module module-bluetooth-policy
pactl load-module module-bluetooth-discover
Might want to check you have pulseaudio-module-bluetooth installed. I was having trouble until I found this post on GitHub Not saying this is an answer to this specific problem but just to make sure.
sudo apt-get install pulseaudio-bluetooth
killall pulseaudio
Zanna
  • 72,312
Try this:
sudo /etc/init.d/bluetooth restart
pulseaudio -k
pulseaudio --start
Then go to the audio manager, and make sure the program that's generating audio has the Bluetooth "sink" as output.
Reference link - https://github.com/blueman-project/blueman/issues/304
