I am running Ubuntu Server 14.04.4 and I didn't install Samba with the original OS setup. I would like to install it now, but I keep getting a error about broken packages. It appears that the main hangup is the samba-libs dependency. It says:
Depends: libldb1 (< 1:1.1.25~) but 2:1.1.17-2 is to be installed
But I already have the latest libldb1 installed. I've tried almost everything I can google, but maybe I'm overlooking something. Any pointers would be greatly appreciated.
Here's whats happening:
root@MAILSVR:/etc/apt# sudo apt-get install samba
Reading package lists... Done
Building dependency tree
Some packages could not be installed.
This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following packages have unmet dependencies: samba : Depends: python-samba but it is not going to be installed
Depends: samba-common-bin (= 2:4.3.8+dfsg-0ubuntu0.14.04.2) but it is not going to be installed
Depends: samba-libs (= 2:4.3.8+dfsg-0ubuntu0.14.04.2) but it is not going to be installed
Recommends: samba-dsdb-modules but it is not going to be installed
Recommends: samba-vfs-modules but it is not going to be installed
Here's what aptitude gives me:
root@MAILSVR:/etc/apt# aptitude install samba
The following NEW packages will be installed:
libwbclient0{a} python-crypto{a} python-ldb{ab} python-samba{a} python-talloc{a} python-tdb{ab} samba samba-common{a} samba-common-bin{a} samba-dsdb-modules{a}
samba-libs{ab} samba-vfs-modules{a} tdb-tools{a}
0 packages upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
Need to get 8,519 kB of archives. After unpacking 48.3 MB will be used.
python-tdb : Depends: libtdb1 (= 1.3.8-0ubuntu0.14.04.1) but 1.3.8-2 is installed.
samba-libs : Depends: libldb1 (< 1:1.1.25~) but 2:1.1.17-2 is installed.
python-ldb : Depends: libldb1 (= 1:1.1.24-0ubuntu0.14.04.1) but 2:1.1.17-2 is installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
python-ldb [Not Installed]
python-samba [Not Installed]
python-tdb [Not Installed]
samba-common-bin [Not Installed]
samba-dsdb-modules [Not Installed]
samba-libs [Not Installed]
samba-vfs-modules [Not Installed]
Leave the following dependencies unresolved:
samba-common recommends samba-common-bin
Accept this solution? [Y/n/q/?]
samba-libs error:
root@MAILSVR:/etc/apt# apt-get install samba-libs
samba-libs : Depends: libldb1 (< 1:1.1.25~) but 2:1.1.17-2 is to be installed
