I have upgraded Ubuntu 22.04 LTS to 23.10 LTS, I have tried to install Samba but I'm having a problem could you please help me to resolve it?
root@13566C-UDHAYAKUMAR:~# sudo apt install samba
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: samba : Depends: samba-common (= 2:4.18.6+dfsg-1ubuntu2) but 2:4.18.6+dfsg-1ubuntu2.1 is to be installed Depends: samba-common-bin (= 2:4.18.6+dfsg-1ubuntu2) but it is not going to be installed Recommends: attr Recommends: python3-markdown but it is not going to be installed Recommends: samba-dsdb-modules but it is not going to be installed Recommends: samba-vfs-modules but it is not going to be installed Recommends: samba-ad-provision but it is not going to be installed E: Unable to correct problems, you have held broken packages.
I have tried after as per this link below as well but it is not working. Also, I have tried sudo apt install nautilus-share but this also gives the same error.
Ajay
  • 2,241
