26
I need to get rid of the GNOME Desktop Environment which has been installed by default when I updated my pc from 15.10 to 16.04.
After a while, I found myself not only with GNOME DE, but also with Cinnamon alongside (in the login screen, I could choose at least five or six DE!)
Now I am using Unity, and I'm happy with that, and I successfully uninstalled Cinnamon, but now I'm afraid that after uninstalling GNOME I will mess up the Unity DE, since I see many packages running in unity with the packagename starting with gnome-... Would someone mind to help me? Thx in advance
5 Answers5
44
To be honest it would be better to back up for files and all config files in the Home folder and do a fresh install of Ubunutu.
If not try this:
Start by running this command:
Uninstall just ubuntu-gnome-desktop
sudo apt-get remove ubuntu-gnome-desktop
sudo apt-get remove gnome-shell
This will remove just the ubuntu-gnome-desktop package itself.
Uninstall ubuntu-gnome-desktop and it's dependencies
sudo apt-get remove --auto-remove ubuntu-gnome-desktop
This will remove the ubuntu-gnome-desktop package and any other dependant packages which are no longer needed.
Purging your config/data too
If you also want to delete your local/config files for ubuntu-gnome-desktop then this will work.
Caution! Purged config/data can not be restored by reinstalling the package.
sudo apt-get purge ubuntu-gnome-desktop
Or similarly, like this ubuntu-gnome-desktop
sudo apt-get purge --auto-remove ubuntu-gnome-desktop
Then run:
sudo apt-get autoremove
to remove extra packages and dependencies no longer needed on your system.
You might (or might not, depending on if gdm was removed already) need to use these commands to change your login screen back to Unity's default (which is lightDM) run
sudo dpkg-reconfigure gdm
Hit enter at the prompt and then select lightdm from the options. After that you can remove gdm with
sudo apt-get remove gdm
Finally run:
sudo apt-get install ubuntu-desktop
sudo apt-get install unity
INFO HERE and HERE
pst007x
  • 8,210
You can see all Gnome package list by :
apt list --installed | grep gnome
then remove your arbitary package by :
apt-get remove <package name>
or remove all packages by:
sudo apt-get remove $(apt list --installed "gnome*" 2>/dev/null | awk -F'/' 'NR>1{print $1}')
I also like the user interface of Unity desktop environment, so try these beautiful steps...
Step 1 : This will remove all gnome related things.
sudo apt-get remove nautilus nautilus-* gnome-power-manager gnome-screensaver gnome-termina* gnome-pane* gnome-applet* gnome-bluetooth gnome-desktop* gnome-sessio* gnome-user* gnome-shell-common zeitgeist-core libzeitgeist* gnome-control-center gnome-screenshot gnome* && sudo apt-get autoremove
Step 2 : This will remove all snap applications, if you don't do this step then you will see that there are 2 same apps some app (like 2 system-monitors, 2 terminals, 2 calculators etc) after installing unity. so run bellow code without any worry.
sudo apt autoremove --purge snapd
Step 3 : Now connect your system to a WI-FI to install Unity .
sudo apt install ubuntu-unity-desktop
Step 4 : After successful installation, reboot your system. You may have a problem that tap to click not working after replacing Gnome with Unity. If so then run below code to solve that problem..
sudo apt install xserver-xorg-input-synaptics
Now reboot your system and Login again.
First, check what is going to be removed
sudo dpkg -l | grep .gnome.
If you are ok with it, run this command
sudo apt autoremove --purge gnome*
Command explanation
# dpkg -l       lists all installed packages
# grep .gnome.   filters, so that only packages with keyword gnome within their names, listed
# purge         removes mentioned package
# autoremove    tries to remove dependency packages
Pran
  • 159
Reboot your system and press Control-Alt-F1 to get to a text terminal. Log in there and type the following:
sudo apt-get install --reinstall lightdm
