71
I used apt install mysql-server to install MySQL on Ubuntu 16.04 but during the installation, it did not ask for root password.
After installation I got ERROR 1045 when I tried to login as root and mysql_secure_installation threw the same error. I purged and autoremoved then reinstalled but it does not work.
How could i fix this? Can I set the root password if I didn't set it during installation?
This is my installation log:
The following additional packages will be installed:
  libaio1 mysql-client-5.7 mysql-client-core-5.7 mysql-server-5.7
  mysql-server-core-5.7
Suggested packages:
  mailx tinyca
The following NEW packages will be installed:
  libaio1 mysql-client-5.7 mysql-client-core-5.7 mysql-server mysql-server-5.7
0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/17,9 MB of archives.
After this operation, 160 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Preconfiguring packages ...
Selecting previously unselected package libaio1:amd64.
(Reading database ... 227144 files and directories currently installed.)
Preparing to unpack .../libaio1_0.3.110-2_amd64.deb ...
Unpacking libaio1:amd64 (0.3.110-2) ...
Selecting previously unselected package mysql-client-core-5.7.
Preparing to unpack .../mysql-client-core-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-client-core-5.7 (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-client-5.7.
Preparing to unpack .../mysql-client-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-client-5.7 (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-server-core-5.7.
Preparing to unpack .../mysql-server-core-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-server-core-5.7 (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-server-5.7.
Preparing to unpack .../mysql-server-5.7_5.7.12-0ubuntu1_amd64.deb ...
Unpacking mysql-server-5.7 (5.7.12-0ubuntu1) ...
Selecting previously unselected package mysql-server.
Preparing to unpack .../mysql-server_5.7.12-0ubuntu1_all.deb ...
Unpacking mysql-server (5.7.12-0ubuntu1) ...
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for systemd (229-4ubuntu4) ...
Processing triggers for ureadahead (0.100.0-19) ...
Setting up libaio1:amd64 (0.3.110-2) ...
Setting up mysql-client-core-5.7 (5.7.12-0ubuntu1) ...
Setting up mysql-client-5.7 (5.7.12-0ubuntu1) ...
Setting up mysql-server-core-5.7 (5.7.12-0ubuntu1) ...
Setting up mysql-server-5.7 (5.7.12-0ubuntu1) ...
update-alternatives: using /etc/mysql/mysql.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Checking if update is needed.
This installation of MySQL is already upgraded to 5.7.12, use --force if you still need to run mysql_upgrade
Setting up mysql-server (5.7.12-0ubuntu1) ...
Zanna
  • 72,312
spqa
  • 823
7 Answers7
70
You can recover or set root password without knowing the current one by starting mysql without loading the grant-tables.
Please note the $ in the commands. This is specifying the terminal prompt you see when typing in the command. It's showing it's a line of text, but and actual typed terminal command. The "mysql>" prefix is also a prompt. That is the prompt you get when running mysql interactivately.
This is the cli (command line) to do this:
(Be sure to stop the current server before performing the steps. Only one server can run at a time.)
$ sudo mkdir /var/run/mysqld; sudo chown mysql /var/run/mysqld
$ sudo mysqld_safe --skip-grant-tables&
Now you can log in as root without a password and perform all commands, as in this case, set the root password as root.
$ sudo mysql --user=root mysql
This is the set root password that you will perform inside mysql if you have MySQL 5.6 or below:
mysql> update user set Password=PASSWORD('new-password') where user='root';
flush privileges;
In MySQL 5.7 or above
mysql> update user set authentication_string=PASSWORD('new-password') where user='root';
flush privileges;
From there, quit (kill the running msqld) mysql and start it as normal.
Notes on starting and stopping the mysql service:
Stop mysql:
$ sudo service mysql stop
Start mysql (normal):
$ sudo service mysql start
Kill the temporary mysql safe mode session:
$ sudo mysqladmin shutdown
L. D. James
  • 25,444
48
It will not ask for the password while installing mysql in Ubuntu 16.04 but you can set it after successful installation in following way:
After completion of mysql installation, run command:
sudo mysql_secure_installation
It will show:
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED FOR ALL MariaDB SERVERS IN PRODUCTION USE! PLEASE READ EACH STEP CAREFULLY!
In order to log into MariaDB to secure it, we'll need the current password for the root user. If you've just installed MariaDB, and you haven't set the root password yet, the password will be blank, so you should just press enter here.
Enter current password for root (enter for none): (here press Enter)
OK, successfully used password, moving on...
Setting the root password ensures that nobody can log into the MariaDB root user without the proper authorisation.
Set root password? [Y/n] y   (press 'y' to set new password)
New password:
Re-enter new password:
Password updated successfully! Reloading privilege tables.. ... Success!
For Ubuntu 18.04 OR mysql-server version 5.7.22, THIS METHOD WILL NOT WORK
To set root password in Ubuntu 18.04, First follow the first three commands or first two steps of L.D. James's answer then run,
mysql> alter user 'root'@'localhost' identified by '<password>';
Password for root user is set!
OR
Follow these steps to set root password in 18.04:
As there is no password set for root user, simply login with blank password
sudo mysql -u root -p
Enter password: (press enter as no password is set)
after then can easily run query
ALTER USER 'root'@'localhost' IDENTIFIED BY '<password>';
d a i s y
  • 5,551
28
After the installation just:
  1. sudo mysql (yes, no user no pass)
  2. You are now in the mysql console. Execute:
    ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY 'my_new_pass';
  3. FLUSH PRIVILEGES;
That's it. You can now enter the console next time as usual:
mysql -u root -pmy_new_pass
DimiDak
  • 741
24
Apparently the mysql-server installation on 16.04 (or any 5.7 installation?) allows root access not through password, but through the auth_socket plugin. Running sudo mysql -u root (n.b. w/o a password) will give you mysql console whereas running the command as non-root prompts you for a password.
It would seem that changing the password doesn't make much of a difference since the auth backend doesn't even check for a password. There is a very comprehensive article on how to change the plugin and switch to password authentication.
carp
  • 357
  1. there is a default user account.
    $ vim /etc/mysql/debian.cnf
    you will get this account from it like this:
    user     = debian-sys-maint
    password = nUZTARYslBsASzpw
  2. you login with this account
    $ mysql -u debian-sys-maint -p
  3. edit you root password
    mysql> show databases;
    mysql> use mysql;
    mysql> update user set authentication_string=PASSWORD("new_password") where user='root';
    mysql> update user set plugin="mysql_native_password";
    mysql> flush privileges;
    mysql> quit;
  4. restart mysql
    $ /etc/init.d/mysql restart;
then you can mysql -u root -p with you previous setting.
pwxcoo
  • 191
Adding to the main answer, If you are stuck at
"mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql"
1 thing to remember that you have to use another terminal window to enter the following command.
If you try to do it in the same window, it will shut down the mysqld safemode process.
-1
Here's how to setup mysql-server with a terminal password prompt in Ubuntu 18.10.
  1. Download The MySQL APT Repository via https://dev.mysql.com/downloads/repo/apt/
  2. cd into your directory where you downloaded and run dpkg -i mysql-apt-config_0.8.13-1_all.deb (check your version number)
  3. From the prompt menu select the last option "ok" and then "ok" again.
  4. Update and install mysql-server and mysql-client:
sudo apt update
sudo apt install mysql-server mysql-client
  1. Type in your root password in the promt.
  2. Select "Use Legacy Authentication Method" if your running frameworks/applications (such as laravel) which do not support the new "Strong Password Encryption" yet, otherwise if your framework/application supports "Strong Password Encryption" then select it.
  3. Login as root and check if it works.
