I recently updated from 15.10 to 16.04 and now my python3 seems to be messed up.
Before the upgrade I had python3.4 and python3.5.1(manually) installed. The upgrade removed python3.4 and replaced it with python3.2 and python3.1.
The new python3.5.1 removed my python3.5.1 installtion.
But now I am facing a lot of issues:
  • check this question
  • comand-not-found does not work anymore and crashes with this traceback (1)
  • if I try to run commmand-not-found with python3.2 (2)
I stripped a few more stuff, as it is always the same.
I do not want to use the old python3 versions, so how can I fix this?
And why is there python3.1?
(1)
 me@my-machine:~$ whareis systemd
 Traceback (most recent call last):
   File "/usr/lib/command-not-found", line 27, in <module>
     from CommandNotFound.util import crash_guard
 ImportError: No module named 'CommandNotFound'
(2)
  File "/usr/lib/python3.2/dbm/gnu.py", line 6, in <module>
    from _gdbm import *
ImportError: No module named _gdbm
Solution: Unlike I mentioned before my python3.5.1 installation was not removed by the update. It was still under /usr/local/bin/python3.5.
Tracing the Error: I wrote a few debug lines into /usr/lib/python3.5/_sysconfigdata.py:
print("python-version", sys.version_info)
print("python-gcc-version",sys.version)
print("python-executable",sys.executable)
The output was different between calling /usr/bin/python3 and rhythmbox, but the python-executable was in both ways /usr/bin/python3
Then I searched for the wrong installation using whereis python3 and removed /usr/local/bin/python3.5
Then I purged and reinstalled python3 and ran apt install -f.
So this Error disappeared.
Remember: never install stuff from source, if it might be in the repos sometime or, at least remove it before your package manager installs it.
Saw the same error in Ubuntu 16.04 with two installations of Python3 (3.5.2 and 3.7.3):
$ junk
ModuleNotFoundError: No module named 'CommandNotFound'
I didn't need python 3.5.2. So, removing it by doing the following resolved the error for me:
sudo apt-get remove --purge python3*
sudo apt autoremove
Then, I see command not found as expected:
$ junk
junk: command not found
