I updated my machine from 15.10 to 16.04 a few days ago.
Now I have to face this strange Issue: rhythmbox tells me, that it Failed to import the site module and crashes, because python3.5 is missing the module _sysconfigdata_m.
I had an installation from source of python3.5.1, but it seems like the release-uprgade removed this installation.
The old python3.5.1´s files were located under /usr/lib/python3.5.1/.
I already tried to reinstall python3.5 and rhythmbox.
The complete traceback:
me@my_machine:~$ rhythmbox
Traceback (most recent call last):
File "/usr/lib/python3.5/site.py", line 580, in <module>
main()
File "/usr/lib/python3.5/site.py", line 566, in main
known_paths = addusersitepackages(known_paths)
File "/usr/lib/python3.5/site.py", line 287, in addusersitepackages
user_site = getusersitepackages()
File "/usr/lib/python3.5/site.py", line 263, in getusersitepackages
user_base = getuserbase() # this will also set USER_BASE
File "/usr/lib/python3.5/site.py", line 253, in getuserbase
USER_BASE = get_config_var('userbase')
File "/usr/lib/python3.5/sysconfig.py", line 595, in get_config_var
return get_config_vars().get(name)
File "/usr/lib/python3.5/sysconfig.py", line 538, in get_config_vars
_init_posix(_CONFIG_VARS)
File "/usr/lib/python3.5/sysconfig.py", line 410, in _init_posix
from _sysconfigdata import build_time_vars
File "/usr/lib/python3.5/_sysconfigdata.py", line 6, in <module>
from _sysconfigdata_m import *
ImportError: No module named '_sysconfigdata_m'
btw:
It seems like 16.04 removed python3.4 (my default python3) and replaced it with python3.2.
Linking /usr/bin/python3.2 to /usr/bin/python3 just caused other python3 programs, like gnome-termial to crash.
Other forums said, that this error appears, if python2 is used instead of python3 so I am a kind of stuck.
Update:
I added some debug output in /usr/lib/python3.5/_sysconfigdata.py:
print(sys.version)
The output is
3.5.1 (default, Feb 10 2016, 15:13:13)
[GCC 5.2.1 20151010]
but it should be
3.5.1+ (default, Mar 30 2016, 22:46:26)
[GCC 5.3.1 20160330]
I have no such python3 installation on my machine! I have searched several times for such an installation.
Edit:
I tried to completely reinstall python3 by running
sudo apt autoremove --purge python3
DO NOT TRY THIS AT HOME!
This will remove nearly all programs on your machine. It took me 6h just to rebuild my base system! I had only one gnome-terminal left, because it was loaded into ram.
But this did not fix my problem.
