After a fresh install (16.04) to my notebook which have Nvidia GT 750m, I want to change GPU driver from "Software & Updates" --> "Additional Drivers". System identifies my graphic card, no problem but when I select a proprietary driver and apply changes. After a few seconds, change bar stops and nouveau selected by default again.
I tried from terminal;
sudo apt-get install nvidia-361
but output says "you have held broken packages"
Reading package lists... Done
Building dependency tree
 nvidia-361 : Depends: lib32gcc1 but it is not going to be installed
              Depends: libc6-i386 but it is not going to be installed
Then issue is not about nvidia-361, all drivers are same.
al0s
  • 549
  • 16
In ubuntu 16.04, if Software & Updates -> Additional Drivers, is started from menu or Unity launcher, choosing a proprietary driver doesn't work. Upon selecting a new driver and clicking apply changes, progress bar moves forward for sometime, then goes back and the previous driver is selected again.
It looks like the issue is that Software & Updates is initialized without super user privileges. The solution is, open a terminal and type:
$ sudo software-properties-gtk
And type password if required. Then select the proprietary driver and click apply changes.
This method solved me the problem.
PS : Edited after seeing the comments.
16.04 is new and all packages are not ready to use in all servers. The problem is not about nvidia drivers or anything about broken pacages.
Using Main Server to download packages solve my problem.
  1. System Settings
  2. Software & Updates
  3. Select "Main Server" from "Download from" section
al0s
  • 549
  • 16
-1
You have a problem with the package system, not with the driver itself. It is quite a common problem. One of the solutions is:
sudo apt-get clean
sudo apt-get install -f
sudo dpkg --configure -a
Another possible solution is to use synaptic package manager to fix the broken packages (it will prompt you to do that automatically) and then you'll be able to install nvidia-361.
Source: Package system is broken. How to fix it?
Dugi
  • 1,077
