32
The new Ubuntu features a completely unkillable GDM. Is there a way to disable it?
It is not enabled in services , the GDM startup script is deleted, it is removed from update.rc but it still starts up.
How do I disable GDM and Graphical User Selection?
A.B.
  • 92,125
krb
  • 423
9 Answers9
23
In Ubuntu 10.04 you should refer to documentation for Upstart which handles starting of tasks and services during boot, stopping them during shutdown and supervising them while the system is running.
Upstart handle start of gdm, so you should edit /etc/init/gdm.conf
sudo vi /etc/init/gdm.conf    # or use nano if vi is unfamiliar
Default runlevel in ubuntu 10.04 is 2 so you must change this line
stop on runlevel [016]
adding "2" in the runlevel list
stop on runlevel [0126]
Now you can reboot the system.
Zanna
  • 72,312
freedev
  • 386
15
Do:
sudo dpkg-divert  --rename --add /etc/init/gdm.conf
Which prints:
Adding `local diversion of /etc/init/gdm.conf to /etc/init/gdm.conf.distrib'
This will allow you to disable GDM while preventing package upgrades from putting the file back in place and allowing the GDM package to upgrade the configuration file.
In the case of 11.x and above lightdm is used instead of GDM. I instead used the command:
sudo dpkg-divert --rename --add /etc/init/lightdm.conf
To undo it replace the rename and add with a remove.
Peachy
  • 7,235
  • 40
  • 47
Erik
  • 151
11
Recent versions of Ubuntu are using upstart instead of SysV init.
Rename /etc/init/gdm.conf to /etc/init/gdm.disabled.
For Kubuntu, rename /etc/init/kdm.conf to /etc/init/kdm.disabled.
10
I found this forum thread to be very helpful:
The solution that I found that worked consistently was post 30 by iscatel:
well, this disables sound, as a previous post pointed out, but here goes:
in /etc/default/grub, comment out (by placing # at the start of the line)
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
and add
GRUB_CMDLINE_LINUX_DEFAULT="text"
then
sudo update-grub2
this will pass "text" to the kernel at boot time line, disabling gdm.
if it still does not work, you can
echo "manual" > /etc/init/gdm.override
and try it again. I used Ubuntu 12.04 32-bit server with GNOME core and it worked for me.
Zanna
  • 72,312
Follow the directions of @freedev on Server Fault:
$ sudo nano /etc/init/gdm.conf
And change to:
Also
$ sudo nano /etc/init/tty1.conf
And change to:
stop on runlevel [!345]
Note the missing 2 in the tty1.conf. This is so that you get tty1 up and running and can log on into the first console. No need to mess with GRUB.
Zanna
  • 72,312
lucian303
  • 132
The prior answers (as of 20160611) discussing runlevels are only relevant for Ubuntu versions using Upstart. Ubuntu 16.04 switched from upstart to systemd. To boot to console, rather than X, you need to change the default target to boot into from graphical to multi-user:
sudo systemctl enable multi-user.target --force
sudo systemctl set-default multi-user.target
Then reboot. To undo this:
sudo systemctl set-default graphical.target
And then reboot.
Zanna
  • 72,312
mrm
  • 165
You can switch to some other display manager (kdm or xdm being two most widespread alternatives, but there are many more, see Wikipedia). Just aptitude install the one you want to use, run dpkg-reconfigure gdm and select it from the list.
minaev
  • 121
Why not just remove it?
apt-get remove gdm
For those who arrive on this topic, follow the instructions of freedev, but instead of stop gdm on run level 2, you should prevent it from starting on runlevel 2 :
Edit /etc/init/gdm.conf
$ sudo vi /etc/init/gdm.conf
Change this line
and runlevel [!06]
By this line
and runlevel [!026]
You can also exclude others run level (3, 4 and 5)
penreturns
  • 5,950
Fabien
