15
After Ubuntu Server 12.04 installation, I installed Xubuntu just to have a minimal GUI:
sudo apt-get install x-window-system-core
sudo apt-get install --no-install-recommends xubuntu-desktop gparted
But now I want to start X just on certain ocasions. Before 12.04, I just issue:
sudo update-rc.d -f gdm remove
But this command does not work anymore.
How can I stop X from init on Ubuntu 12.04 ? And how can I start it when I need it ?
I have tried both of these questions but I don't have a gdm.conf:
josircg
  • 1,259
  • 16
  • 25
6 Answers6
26
For Ubuntu 18.04 this worked for me:
Disable gdm
This will prevent gdm from loading on boot and login is via console.
systemctl set-default multi-user.target
Using this method, gdm can still be started manually with systemctl start gdm
Check the systemd default with
systemctl get-default
Usually this will be graphical.target and can be reverted with systemctl set-default graphical.target
Source: https://wiki.debian.org/GDM#systemd
15
In recent versions of Ubuntu, gdm has been replaced with lightdm - this is why you don't have a gdm.conf. To set lightdm to be started manually, create an 'override' file for its init configuration:
echo 'manual' | sudo dd of=/etc/init/lightdm.override
(this just creates a file, called /etc/init/lightdm.override, containing a single line that says manual)
This way, lightdm will only be started when you invoke:
sudo service lightdm start
and to stop it:
sudo service lightdm stop
Jeremy Kerr
  • 27,829
just want to share , may be it become helpful to any one .
I installed Ubuntu Server 12.04 and later installed graphical interface kubuntu-desktop
now when i wanted to disable graphical startup/login I tried all the options
/etc/default/grub .. making the entry GRUB_CMDLINE_LINUX_DEFAULT="text" in place of "quiet splash"
update-grub
update-rc.d -f ldm remove
update-rc.d -f kdm remove
as well as
echo 'manual' | sudo tee /etc/init/lightdm.override
Nothing worked. Then I edited the /etc/init/kdm.conf , and added 2 default runlevel to and runlevel [!026]
stop on runlevel [0126]
#start on ((filesystem
#           and runlevel [!026]
#           and started dbus
#           and (drm-device-added card0 PRIMARY_DEVICE_FOR_DISPLAY=1
#                or stopped udev-fallback-graphics))
#          or runlevel PREVLEVEL=S)
#stop on runlevel [0126]
It worked.
user68186
  • 37,461
Ali
  • 41
I installed Ubuntu Server 12.04 on a netbook, mainly because I'm more of a fan of CLI then I am of GUI, but wanted a light GUI for small things. I installed LXDE, not Lubuntu, but it would start LXDM, the login manager for LXDE. I looked all over and tried many things to get this to stop loading LXDE. After looking at this question and answer, I found a good way of stopping it for LXDE.
Instead of adding a file similar to lightdm.override, I was looking in /etc/init and found a file called lxdm.conf. After looking through the file, mainly because I was curious, I found that this is the file that I needed, or didn't need. After closing the file, I renamed it
    sudo mv /etc/init/lxdm.conf /etc/init/lxdm.conf.bak
I renamed it instead of removing it in case it caused problems, but so far I can't tell any problems from renaming this file, so it should be safe to remove.
I don't know about other DE's but this worked for me with LXDE.
Anthony
Check systemctl get-default.
If the output is graphical.target, then set it to multi-user.target with systemctl set-default:
Reference this link for more on systemd-targets: 10.3. Working with systemd Targets
Eliah Kagan
  • 119,640
James
The following is for Ubuntu Server 12 LTS
First you need open a real term with CTRL+ALT F1
login
Stop gdm with:
$ sudo service gdm stop
Remove gdm you don't need it at all on a server.
$ sudo apt-get remove gdm
Set next boot runlevel with.
$ sudo telinit 3
Without gdm you will need to install xinit if you want to still be able to run gui based apps without the gdm window manager.
$ sudo apt-get install xinit
Reboot to runlevel 3.
$ sudo reboot
To run a GUI or desktop after reboot do.
$ startx
This will start your gnome session as normal.
When finished simply logout of your desktop to and drop you back to a level 3 term.
Also you can now start individual apps without a desktop too like:
$ startx nautilus
or privileged with
$ startx sudo synaptic
bummi
  • 394
BamBam
