X2GO with Ubuntu Mate 16.04 fails to start with the following error message in ~/.xsession-x2go-errors
XSession-x2go: X session started for testuser at Fri Apr  26 22:30:23 EDT 2016
localuser:testuser being added to access control list
/etc/x2go/Xsession: 3: [: x: unexpected operator
mate-session[3684]: GLib-GIO-CRITICAL: g_settings_schema_source_lookup: assertion 'source != NULL' failed
mate-session[3684]: GLib-GIO-ERROR: No GSettings schemas are installed on the system
aborting...
nkef
  • 1,151
  • 15
To work around the problem set in ~/.profile the system default value for XDG_DATA_DIRS and to GSETTINGS_SCHEMA_DIR.
export GSETTINGS_SCHEMA_DIR=/usr/share/mate:/usr/share/mate:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
export XDG_DATA_DIRS=/usr/share/mate:/usr/share/mate:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
nkef
  • 1,151
  • 15
great idea! I had this issue too. If you want to have x2go with Mate working for all users enabled I would put this
into /etc/profile instead. Have fun!
same thing on xfce4 but I didn't have the same error message: more a lot of error message as:
    (polkit-gnome-authentication-agent-1:28411): GLib-GObject-CRITICAL **: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(polkit-gnome-authentication-agent-1:28411): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(polkit-gnome-authentication-agent-1:28411): Gdk-CRITICAL **: gdk_cairo_surface_create_from_pixbuf: assertion 'GDK_IS_PIXBUF (pixbuf)' failed
(polkit-gnome-authentication-agent-1:28411): Gtk-WARNING **: Error loading theme icon 'gtk-cancel' for stock: Unrecognized image file format
(polkit-gnome-authentication-agent-1:28411): Gtk-WARNING **: Error loading theme icon 'image-missing' for stock: L'icône « image-missing » n'est pas présente dans le thème elementary-xfce-dark
now its working by just adding the 2 lines from your post and change mate to xfce4
vigilian
  • 854
