On Windows 10, my laptop's keyboard backlit automatically turned off after a minute or so of inactivity. As soon as any activity occurred, they turned back on.
On ubuntu, if I run the following
echo <0-3> | sudo tee /sys/class/leds/asus::kbd_backlight/brightness
That works for dimming / increasing the brightness (0 being turned off, 3 being brightest).
Is there a way to have the above automatically get executed whenever the system's been idle for 1 minute, as well as re-run it when it comes back from being idle?
Thanks.
Jacob Vlijm
  • 85,475
What you need to do
  1. Install xprintidle, to keep track of the current idle time (defined by lack of keyboard- and mouse events).
  2. Create a small background script (further below); copy the script into an empty file and save it as dim_keyboard.sh. Make the script executable and copy it to a location where unauthorized users cannot alter the script (e.g. /usr/local/bin).
  3. Add the script to the sudoers file, since you run the command with sudo: Add the line:
    <username> ALL= NOPASSWD: /path/to/your/script
    (where <username> is your username) to the file, as explained e.g. here.
N.B. In the sudoers file, for security reasons always use the full path to the script, also if it is in $PATH. The reason is that else it would be easy to place a similarly named script in ~/bin, which could run with sudo privileges, possibly with malicious code.
  1. Test- run the script with the idle time (in seconds) as an argument:
    sudo /path/to/script.sh 60
    To dim the backlight after a minute
  2. If all works fine, add it to Startup Applications: Dash > Startup Applications > Add. add the command:
The script:
#!/bin/bash
let "div = 1000"
let "limit = $1"
dimmed=false
cmd=/sys/class/leds/asus::kbd_backlight/brightness
while true
do
  sleep 2
  let "idle = $(xprintidle)"
  if [ $(($idle / $div)) -gt $limit ] && [ $dimmed == false ]; then
    echo 0 | tee $cmd
    dimmed=true
  elif [ $(($idle / $div)) -le $limit ] && [ $dimmed == true ]; then
    echo 3 | tee $cmd
    dimmed=false
  fi
done
Jacob Vlijm
  • 85,475
To continue the https://askubuntu.com/a/762994/954857 answer. Do add the following
savedState=$(cat /sys/class/leds/asus::kbd_backlight/brightness)
Use this line to save the older state and reuse so the brightness will always be the same
Vinay P
