I just upgraded to ubuntu 16.04 and I started having problems with vmware (v 12.1.0 build-3272444).
When I try to play the virtual machine I receive the following error: Could not open /dev/vmmon: No such file or directory. Please make sure that the kernel module vmmon is loaded. followed by Failed to initialize monitor device.
I have spent some time in forums trying to find a solution. Typically in cases like this it is recommended to execute sudo vmware-modconfig --console --install-all, however in my case this doesn't work. In the command log I can see that there are issues.
Starting VMware services:
Virtual machine monitor failed
Virtual machine communication interface done
VM communication interface socket family done
Blocking file system done
Virtual ethernet failed
VMware Authentication Daemon done
Unable to start services
In the vmware log as well I can see that there problems. I tried to look for solutions to the issue generating the message: Failed to find /lib/modules/4.4.0-21-generic/build/include/linux/version.h, but without success.
2016-04-24T17:07:45.101+01:00| vthread-4| I125: The GCC version matches the kernel GCC minor version like a glove.
2016-04-24T17:07:45.101+01:00| vthread-4| I125: Validating path "/lib/modules/4.4.0-21-generic/build/include" for kernel release "4.4.0-21-generic".
2016-04-24T17:07:45.101+01:00| vthread-4| I125: Failed to find /lib/modules/4.4.0-21-generic/build/include/linux/version.h
2016-04-24T17:07:45.101+01:00| vthread-4| I125: /lib/modules/4.4.0-21-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2016-04-24T17:07:45.101+01:00| vthread-4| I125: using /usr/bin/gcc for preprocess check
2016-04-24T17:07:45.115+01:00| vthread-4| I125: Preprocessed UTS_RELEASE, got value "4.4.0-21-generic".
2016-04-24T17:07:45.115+01:00| vthread-4| I125: The header path "/lib/modules/4.4.0-21-generic/build/include" for the kernel "4.4.0-21-generic" is valid. Whoohoo!
2016-04-24T17:07:45.115+01:00| vthread-4| I125: Using temp dir "/tmp".
2016-04-24T17:07:45.116+01:00| vthread-4| I125: Obtaining info using the running kernel.
2016-04-24T17:07:45.116+01:00| vthread-4| I125: Setting header path for 4.4.0-21-generic to "/lib/modules/4.4.0-21-generic/build/include".
2016-04-24T17:07:45.116+01:00| vthread-4| I125: Validating path "/lib/modules/4.4.0-21-generic/build/include" for kernel release "4.4.0-21-generic".
2016-04-24T17:07:45.116+01:00| vthread-4| I125: Failed to find /lib/modules/4.4.0-21-generic/build/include/linux/version.h
2016-04-24T17:07:45.116+01:00| vthread-4| I125: /lib/modules/4.4.0-21-generic/build/include/linux/version.h not found, looking for generated/uapi/linux/version.h instead.
2016-04-24T17:07:45.116+01:00| vthread-4| I125: using /usr/bin/gcc for preprocess check
2016-04-24T17:07:45.123+01:00| vthread-4| I125: Preprocessed UTS_RELEASE, got value "4.4.0-21-generic".
2016-04-24T17:07:45.123+01:00| vthread-4| I125: The header path "/lib/modules/4.4.0-21-generic/build/include" for the kernel "4.4.0-21-generic" is valid. Whoohoo!
2016-04-24T17:07:45.289+01:00| vthread-4| I125: found symbol version file /lib/modules/4.4.0-21-generic/build/Module.symvers
2016-04-24T17:07:45.289+01:00| vthread-4| I125: Reading symbol versions from /lib/modules/4.4.0-21-generic/build/Module.symvers.
2016-04-24T17:07:45.314+01:00| vthread-4| I125: Read 18759 symbol versions
2016-04-24T17:07:45.314+01:00| vthread-4| I125: Invoking modinfo on "vmmon".
2016-04-24T17:07:45.316+01:00| vthread-4| I125: "/sbin/modinfo" exited with status 0.
2016-04-24T17:07:45.316+01:00| vthread-4| I125: Invoking modinfo on "vmnet".
2016-04-24T17:07:45.319+01:00| vthread-4| I125: "/sbin/modinfo" exited with status 0.
Any help would be greatly appreciated!
Andreas
