13
I've performed a fresh installation of Ubuntu 16.04 on my Asus N56VZ. Sadly, i cannot connect to wireless networks using the NetworkManager. I am able to see wireless networks, though.
I tried to connect to my network using the GUI and entered my password. But after that, nothing happens. I see no attempt to connect to this network, and I don't get an error either. I can see that the network manager saved my network, and I double and triple-checked whether the password and all other configurable parameters are correct.
Funny thing is - I am able to connect using nmtui without any problems.
I have not been able to test whether this is a problem with this specific network or if it is a general problem. I highly suspect the latter though, as I had no problem using said network on Ubuntu 15.04.
Output of some interesting commands:
Before connecting using nmtui:
iwconfig
enp4s0    no wireless extensions.
lo        no wireless extensions.
wlp3s0    IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
lspci -vvnn | grep Network
03:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
    Subsystem: AzureWave AR9485 Wireless Network Adapter [1a3b:2c97]
sudo service NetworkManager status (after I tried and failed to establish a connectiong using the NetworkManager)
● NetworkManager.service - Network Manager
   Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
   Active: active (running) since So 2016-04-24 00:03:32 CEST; 15min ago
 Main PID: 788 (NetworkManager)
    Tasks: 3 (limit: 512)
   CGroup: /system.slice/NetworkManager.service
           └─788 /usr/sbin/NetworkManager --no-daemon
Apr 24 00:18:24 Tesla NetworkManager[788]: <info>  [1461449904.2249] device (wlp3s0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Apr 24 00:18:24 Tesla NetworkManager[788]: <info>  [1461449904.2253] manager: NetworkManager state is now CONNECTING
Apr 24 00:18:24 Tesla NetworkManager[788]: <info>  [1461449904.2265] device (wlp3s0): state change: prepare -> config (reason 'none') [40 50 0]
Apr 24 00:18:24 Tesla NetworkManager[788]: <info>  [1461449904.2270] device (wlp3s0): Activation: (wifi) access point 'FRITZ!Box 7362 SL' has security, but secrets are required.
Apr 24 00:18:24 Tesla NetworkManager[788]: <info>  [1461449904.2277] device (wlp3s0): state change: config -> need-auth (reason 'none') [50 60 0]
Apr 24 00:18:49 Tesla NetworkManager[788]: <warn>  [1461449929.2418] device (wlp3s0): No agents were available for this request.
Apr 24 00:18:49 Tesla NetworkManager[788]: <info>  [1461449929.2419] device (wlp3s0): state change: need-auth -> failed (reason 'no-secrets') [60 120 7]
Apr 24 00:18:49 Tesla NetworkManager[788]: <info>  [1461449929.2422] manager: NetworkManager state is now DISCONNECTED
Apr 24 00:18:49 Tesla NetworkManager[788]: <warn>  [1461449929.2427] device (wlp3s0): Activation: failed for connection 'FRITZ!Box 7362 SL'
Apr 24 00:18:49 Tesla NetworkManager[788]: <info>  [1461449929.2437] device (wlp3s0): state change: failed -> disconnected (reason 'none') [120 30 0]
After connecting, iwconfig yields:
wlp3s0    IEEE 802.11bgn  ESSID:"FRITZ!Box 7362 SL"
          Mode:Managed  Frequency:2.427 GHz  Access Point: 34:31:C4:30:7D:13
          Bit Rate=72.2 Mb/s   Tx-Power=15 dBm
          Link Quality=66/70  Signal level=-44 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:105   Missed beacon:0
I would be happy for any suggestions.
Pablo Bianchi
  • 17,371
Mesaph
  • 151
I have been having the same issue, While not a fix, I found that restarting the network manager works. I have included the instructions to do this below.
From the command line
Stopping Network Manager
sudo /etc/init.d/network-manager stop
Starting Network Manager
sudo /etc/init.d/network-manager start
dedunu
  • 9,556
ubuntu 16.04 doesn't have properly configured wireless driver.. I installed Ubuntu 16.04 in 3 machines and no one came with working wireless. Straight forward solution could be, user Ethernet cable to use Internet, then
  • sudo apt-get update
  • now goto > system setting > software updates > additional driver
  • now if it shows wireless driver, install it and you are done.
If it doesn't solves your problem you probably need to use logging tools like dmesg, syslog, journalctl, lshw.. know your wireless hardware and google the respective driver.
Videonauth
  • 33,815
I solved the problem by typing my password into a document, and then copying and pasting it into the password field.
For some reason the connection was timing out before I could type my (long) password in but not giving me any messages about it.
Anna
  • 41
