I don't have any programing background. So, I was upgrading the system via terminal, when it just started, i pressed suspend, instead of lock. The screen froze. I switched it off. And when restarting, it give a terminal like screen. Asking for Login and password. I used ecryptfs to check if my partition still exists. I entered my login name and password and the mount passphrase. It works and indicated that the partition is mounted and decrypted. So, I tried to do the same process using live CD. I get a response that my partition is recovered and mount. It asks for login credential, and it accepts it. But I face à problem with the mount passphrase wrapping. Can anyone please help me? Thanks
Asked
Active
Viewed 93 times
Try to update and upgrade
You're setup seems to be interrupted during a update. But since you have a terminal infront of you, cou can still fix everything. Just run these commands and pay attention to the qesions asked on your screen:
sudo -i # change user to root
apt update # get the newes information form the ubuntu repository servers
apt upgrade # installs the newer packages
I think, you will get some inforamtions during your the apt commands, espacially the last lines before you can enter something. I think they can helpo you too.
Test internetconnection
You can test your internetconnection with these two commands.
host security.archive.ubuntu.com
ping -c 8 1.1.1.1
From your infromation given in the comments, it seems your network is not working.
If you got a Lan-cable, use it. Else, try nmtui or other suggestions from here.
Then run a testcomand from above.
Boba Fit
- 1,693
