12
The following command worked fine on Ubuntu 15.10:
sudo apt-get build-dep emacs24
However, on Ubuntu 16.04 I get the following error when running it:
Reading package lists... Done
E: You must put some 'source' URIs in your sources.list
In 15.10 all lines (around 10 in number) with deb-src in /etc/apt/sources.list where uncommented, whereas in 16.04 the corresponding lines where commented out. For example, here are 4 lines from my current sources.list:
## Major bug fix updates produced after the final release of the
## distribution.
deb http://no.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
# deb-src http://no.archive.ubuntu.com/ubuntu/ xenial-updates main restricted
What is the reason for this change?
Next, I would like to avoid manually edit /etc/apt/sources.list each time I do a reinstallation of Ubuntu. How can this (uncommenting the deb-src lines) be done automatically?
6 Answers6
15
I had this same issue on a server install of Ubuntu 16.04, so no GUI. All that I needed was a couple of sed commands.
sudo sed -i -- 's/#deb-src/deb-src/g' /etc/apt/sources.list && sudo sed -i -- 's/# deb-src/deb-src/g' /etc/apt/sources.list
Then sudo apt-get update and continue on.
heemayl
  • 93,925
Tobi
  • 151
10
Open Software & Updates and enable "Source code".
Here is a (currently untested) Bash script that could be used to uncomment deb-src lines in sources.list :
tempdir=$(mktemp -d)
cd "$tempdir"
source_file=/etc/apt/sources.list
new_file=sources.list.new
perl -pE 's/^#\s+(deb-src)/$1/' "$source_file" > "$new_file"
sudo cp "$new_file" "$source_file"
sudo apt-get update
simpler solution that does what the others have posted more succinctly:
sudo perl -p -i -n -e "s/# *deb-src/deb-src/"  /etc/apt/sources.list
Key distinctions: Perl has the -i inplace option which modifies files in place; I did not add a suffix for backup files because I didn't want the backup files to accidentally be treated as data files. And " *" deals with optional whitespace. "perl -p -n -e" is mostly the same as "sed -e", though watch out for greedy regex matching.
It has the same limitations the others do: it enables sources even if the original wasn't enabled (i.e. partners), and it doesn't work on /etc/apt/sources.list.d. The following will also process /etc/apt/sources.list.d* but makes a backup first.
(cd /etc/apt/; sudo tar cvf sources.list.tar sources.list sources.list.d);  for i in /etc/apt/sources.list /etc/apt/sources.list.d/*; do sudo perl -p -i -n -e "s/# *deb-src/deb-src/" $i; done
whitis
  • 121
Here is a simplification of @Tobi's result that does it on a single call to sed:
sed -i -- 's/#\s\?deb-src/deb-src/g' /etc/apt/sources.list
This adds \s\? which is an optional white space (note the ? needs to be escaped).
lanoxx
  • 1,249
You can safely run this snipped as root on any Debian/Ubuntu system:
if [ -f /etc/apt/sources.list ]
then
  grep '^deb ' /etc/apt/sources.list | \
    sed 's/^deb /deb-src /g' > /etc/apt/sources.list.d/sources-list-with-deb-src.list
fi
if [ -f /etc/apt/sources.list.d/debian.sources ] then sed 's/Types: deb/Types: deb deb-src/g' -i /etc/apt/sources.list.d/debian.sources fi
This will work both on old Ubuntu/Debian releases as the if clause will automatically detect if the system has the old or new apt repository configuration format. No other replies to this question were considering the possibility of the new sources file syntax (https://manpages.debian.org/unstable/apt/sources.list.5.en.html).
Code copied from https://salsa.debian.org/otto/debcraft/-/blob/e6e8a36a700b4ad46f0bc0f44c88def3dd680e9e/src/container/enable-source-repositories.sh which has a longer explanation.
Otto
  • 6,154
