28
I am trying to compile emacs on Ubuntu 12.04. This is because I want to use Emacs 24.2.
However, I am getting the following error. How can I fix it?
checking for long file names... yes
checking for X... no
checking for X... true
configure: error: You seem to be running X, but no X development libraries
were found.  You should install the relevant development files for X
and for the toolkit you want, such as Gtk+, Lesstif or Motif.  Also make
sure you have development files for image handling, i.e.
tiff, gif, jpeg, png and xpm.
If you are sure you want Emacs compiled without X window support, pass
  --without-x
to configure.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
michael
  • 6,259
I used to do it this way:
sudo apt-get install build-essential texinfo libx11-dev libxpm-dev libjpeg-dev libpng-dev libgif-dev libtiff-dev libgtk-3-dev libncurses-dev libgnutls28-dev
# for gtk2 build replace libgtk-3-dev with libgtk2.0-dev
git clone --depth=1 git://git.savannah.gnu.org/emacs.git
cd emacs
./autogen.sh # not needed when installing from tarball
./configure
make bootstrap
sudo make install
To build docs:
make docs
# or build just the format you want:
make info
make dvi
make html
make pdf
But now I just use the package
sudo add-apt-repository -y ppa:ubuntu-elisp
sudo apt-get update
sudo apt-get install emacs-snapshot
Adobe
  • 3,971
15
If you run
sudo apt-get build-dep emacs23
that installs everything that is needed to compile the emacs23 package. Quite likely that's enough to compile Emacs 24.2, too.
