18
After upgrade to Ubuntu 16.04, Steam doesn't start. When I execute it from the command line, I get the following error:
$ steam
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
grep: symbol lookup error: grep: undefined symbol: pcre_jit_stack_alloc
Installing breakpad exception handler for appid(steam)/version(1459463254)
Cristiana Nicolae
  • 4,570
  • 32
  • 46
Senpai
  • 181
I upgraded from 14.04 LTS to 16.04 LTS and also wasn't able to start Steam. It started (I mean, 'steam' continued to be running), but nothing happened after a few seconds.
For me, the workaround I finally found was to run Steam from commandline with:
LD_PRELOAD='/usr/$LIB/libstdc++.so.6' steam
Non-essential information below.
Steam provides essentially a "mini distribution" with it, called Steam Runtime, but it isn't currently doing a complete job so it somehow clashes with system C++ standard library and/or other libraries. During my experiments I had also a complaint of system libreadline6 <-> Steam runtime libtinfo5. After I manually unpacked the steam runtime tarball package under the Steam directory to overwrite what I previously had there, it changed to be as described in this problem (pcre_jit_stack_alloc).
An interesting tidbit is that before I found the solution above, I was able to start Steam so it downloaded an upgrade for itself by disabling the Steam Runtime temporarily with export STEAM_RUNTIME=0. Steam itself wouldn't run but that was my first step forward. I tried installing system equivalents of the 32-bit libraries required, but didn't finish / get it working.
Executing the following command works everytime for me.
LD_PRELOAD='/usr/$LIB/libstdc++.so.6 /$LIB/libgcc_s.so.1 /usr/$LIB/libxcb.so.1 /$LIB/libgpg-error.so.0' steam
ulidtko
  • 5,988
