I have Lenovo G50-30 and I have installed Ubuntu 14.04 Gnome LTS and my wifi is hard blocked, I can connect via ethernet but nothing helps me with unblocking wifi. In BIOS wifi is enabled. I've tried rfkill unblock all but it didn't help here is info from script I've found:
########## wireless info START ##########
Report from: 23 Apr 2016 15:13 CEST +0200
Booted last: 23 Apr 2016 14:56 CEST +0200
Script from: 27 Sep 2015 00:34 UTC +0000
##### release ###########################
Distributor ID: Ubuntu
Description: Ubuntu 14.04.3 LTS
Release: 14.04
Codename: trusty
##### kernel ############################
Linux 3.19.0-25-generic #26~14.04.1-Ubuntu SMP Fri Jul 24 21:16:20 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Parameters: ro, quiet, splash, vt.handoff=7
##### desktop ###########################
sed: can't read /root/.dmrc: No such file or directory
Could not be determined.
##### lspci #############################
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
Subsystem: Lenovo Device [17aa:b736]
Kernel driver in use: rtl8723be
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 10)
Subsystem: Lenovo Device [17aa:3816]
Kernel driver in use: r8168
##### lsusb #############################
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0bda:b728 Realtek Semiconductor Corp.
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 5986:0652 Acer, Inc
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 002: ID 17ef:6053 Lenovo
##### PCMCIA card info ##################
##### rfkill ############################
0: ideapad_wlan: Wireless LAN
Soft blocked: yes
Hard blocked: yes
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: yes
3: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
##### lsmod #############################
rtl8723be 143360 0
btcoexist 184320 1 rtl8723be
rtl_pci 40960 1 rtl8723be
rtlwifi 102400 3 btcoexist,rtl_pci,rtl8723be
mac80211 708608 3 rtl_pci,rtlwifi,rtl8723be
cfg80211 524288 2 mac80211,rtlwifi
snd_soc_rt5640 94208 0
snd_soc_rl6231 16384 1 snd_soc_rt5640
snd_soc_core 196608 2 snd_soc_rt5640,snd_soc_sst_mfld_platform
snd_pcm 106496 8 snd_soc_rt5640,snd_soc_core,snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_soc_sst_mfld_platform,snd_hda_controller,snd_pcm_dmaengine
ideapad_laptop 20480 0
sparse_keymap 16384 1 ideapad_laptop
##### interfaces ########################
auto lo
iface lo inet loopback
##### ifconfig ##########################
eth0 Link encap:Ethernet HWaddr <MAC 'eth0' [IF]>
inet addr:192.168.0.13 Bcast:192.168.0.31 Mask:255.255.255.224
inet6 addr: fe80::<IP6 'eth0' [IF]>/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:9395 errors:0 dropped:0 overruns:0 frame:0
TX packets:5583 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:5586646 (5.5 MB) TX bytes:687926 (687.9 KB)
Interrupt:89 Base address:0x6000
wlan0 Link encap:Ethernet HWaddr <MAC 'wlan0' [IF]>
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
##### iwconfig ##########################
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Encryption key:off
Power Management:on
##### route #############################
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 eth0
192.168.0.0 0.0.0.0 255.255.255.224 U 1 0 0 eth0
##### resolv.conf #######################
nameserver 127.0.1.1
##### network managers ##################
Installed:
NetworkManager
Running:
root 824 1 0 14:56 ? 00:00:00 NetworkManager
##### NetworkManager info ###############
NetworkManager Tool
State: connected (global)
- Device: wlan0 ----------------------------------------------------------------
Type: 802.11 WiFi
Driver: rtl8723be
State: unavailable
Default: no
HW Address: <MAC 'wlan0' [IF]>
Capabilities:
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points
- Device: eth0 [Wired connection 1] -------------------------------------------
Type: Wired
Driver: r8168
State: connected
Default: yes
HW Address: <MAC 'eth0' [IF]>
Capabilities:
Carrier Detect: yes
Speed: 1000 Mb/s
Wired Properties
Carrier: on
IPv4 Settings:
Address: 192.168.0.13
Prefix: 27 (255.255.255.224)
Gateway: 192.168.0.1
DNS: 89.231.1.206
DNS: 217.172.224.160
##### NetworkManager.state ##############
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
##### NetworkManager.conf ###############
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
##### NetworkManager profiles ###########
##### iw reg get ########################
Region: Europe/Warsaw (based on set time zone)
country 00:
(2402 - 2472 @ 40), (3, 20)
(2457 - 2482 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(2474 - 2494 @ 20), (3, 20), NO-OFDM, PASSIVE-SCAN, NO-IBSS
(5170 - 5250 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
(5735 - 5835 @ 40), (3, 20), PASSIVE-SCAN, NO-IBSS
##### iwlist channels ###################
eth0 no frequency information.
lo no frequency information.
wlan0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
##### iwlist scan #######################
eth0 Interface doesn't support scanning.
wlan0 Interface doesn't support scanning : Network is down
lo Interface doesn't support scanning.
##### module infos ######################
[rtl8723be]
filename: /lib/modules/3.19.0-25-generic/kernel/drivers/net/wireless/rtlwifi/rtl8723be/rtl8723be.ko
firmware: rtlwifi/rtl8723befw.bin
description: Realtek 8723BE 802.11n PCI wireless
license: GPL
author: Realtek WlanFAE <wlanfae@realtek.com>
author: PageHe <page_he@realsil.com.cn>
srcversion: 00619764255210776FAB54D
depends: rtlwifi,rtl_pci,btcoexist,mac80211
vermagic: 3.19.0-25-generic SMP mod_unload modversions
parm: swlps:bool
parm: swenc:using hardware crypto (default 0 [hardware])
(bool)
parm: ips:using no link power save (default 1 is open)
(bool)
parm: fwlps:using linked fw control power save (default 1 is open)
(bool)
parm: msi:Set to 1 to use MSI interrupts mode (default 0)
(bool)
parm: debug:Set debug level (0-5) (default 0) (int)
parm: disable_watchdog:Set to 1 to disable the watchdog (default 0)
(bool)
parm: ant_sel:Set to 1 or 2 to force antenna number (default 0)
(int)
[rtl_pci]
filename: /lib/modules/3.19.0-25-generic/kernel/drivers/net/wireless/rtlwifi/rtl_pci.ko
description: PCI basic driver for rtlwifi
license: GPL
author: Larry Finger <Larry.FInger@lwfinger.net>
author: lizhaoming <chaoming_li@realsil.com.cn>
srcversion: 8552A7BAFD0FCC2C41CF075
depends: mac80211,rtlwifi
[rtlwifi]
filename: /lib/modules/3.19.0-25-generic/kernel/drivers/net/wireless/rtlwifi/rtlwifi.ko
description: Realtek 802.11n PCI wireless core
license: GPL
srcversion: 990116D31097F1C4C1F7006
depends: mac80211,cfg80211
[mac80211]
filename: /lib/modules/3.19.0-25-generic/kernel/net/mac80211/mac80211.ko
license: GPL
description: IEEE 802.11 subsystem
srcversion: B23264F074A7D27F8B691A2
depends: cfg80211
intree: Y
signer: Magrathea: Glacier signing key
sig_key: 6A:AA:11:D1:8C:2D:3A:40:B1:B4:DB:E5:BF:8A:D6:56:DD:F5:18:38
sig_hashalgo: sha512
parm: minstrel_vht_only:Use only VHT rates when VHT is supported by sta. (bool)
parm: max_nullfunc_tries:Maximum nullfunc tx tries before disconnecting (reason 4). (int)
parm: max_probe_tries:Maximum probe tries before disconnecting (reason 4). (int)
parm: beacon_loss_count:Number of beacon intervals before we decide beacon was lost. (int)
parm: probe_wait_ms:Maximum time(ms) to wait for probe response before disconnecting (reason 4). (int)
parm: ieee80211_default_rc_algo:Default rate control algorithm for mac80211 to use (charp)
[cfg80211]
filename: /lib/modules/3.19.0-25-generic/kernel/net/wireless/cfg80211.ko
description: wireless configuration support
license: GPL
author: Johannes Berg
srcversion: E61EB836E1B33C2A2918485
depends:
intree: Y
parm: ieee80211_regdom:IEEE 802.11 regulatory domain code (charp)
parm: cfg80211_disable_40mhz_24ghz:Disable 40MHz support in the 2.4GHz band (bool)
##### module parameters #################
[rtl8723be]
ant_sel: 0
debug: 1
disable_watchdog: N
fwlps: N
ips: N
msi: N
swenc: N
swlps: N
[mac80211]
beacon_loss_count: 7
ieee80211_default_rc_algo: minstrel_ht
max_nullfunc_tries: 2
max_probe_tries: 5
minstrel_vht_only: Y
probe_wait_ms: 500
[cfg80211]
cfg80211_disable_40mhz_24ghz: N
ieee80211_regdom: 00
##### /etc/modules ######################
lp
rtc
r8168
##### modprobe options ##################
[/etc/modprobe.d/blacklist-ath_pci.conf]
blacklist ath_pci
[/etc/modprobe.d/blacklist.conf]
blacklist evbug
blacklist usbmouse
blacklist usbkbd
blacklist eepro100
blacklist de4x5
blacklist eth1394
blacklist snd_intel8x0m
blacklist snd_aw2
blacklist i2c_i801
blacklist prism54
blacklist bcm43xx
blacklist garmin_gps
blacklist asus_acpi
blacklist snd_pcsp
blacklist pcspkr
blacklist amd76x_edac
blacklist r8169
blacklist wmi
[/etc/modprobe.d/blacklist-rare-network.conf]
alias net-pf-3 off
alias net-pf-6 off
alias net-pf-9 off
alias net-pf-11 off
alias net-pf-12 off
alias net-pf-19 off
alias net-pf-21 off
alias net-pf-36 off
[/etc/modprobe.d/iwlwifi.conf]
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
[/etc/modprobe.d/mlx4.conf]
softdep mlx4_core post: mlx4_en
[/etc/modprobe.d/rtl8723be.conf]
options rtl8723be fwlps=N ips=N
##### rc.local ##########################
exit 0
##### pm-utils ##########################
##### udev rules ########################
[/etc/udev/rules.d/70-persistent-net.rules]
# PCI device 0x10ec:0x8168 (r8169)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'eth0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="eth*", NAME="eth0"
# PCI device 0x10ec:0xb723 (rtl8723be)
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="<MAC 'wlan0' [IF]>", ATTR{dev_id}=="0x0", ATTR{type}=="1", KERNEL=="wlan*", NAME="wlan0"
##### dmesg #############################
[ 11.418691] eth0: 0xffffc90004776000, <MAC 'eth0' [IF]>, IRQ 89
[ 11.469772] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.117640] Using firmware rtlwifi/rtl8723befw.bin
[ 12.117821] rtlwifi: channel plan 0x20
[ 12.117824] rtlwifi: country code 11
[ 12.129494] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 12.130214] rtlwifi: wireless switch is on
[ 15.485070] r8168: eth0: link up
[ 15.485132] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
########## wireless info END ############
