30
Since I upgraded to the latest version of Ubuntu, I cannot install the Java OpenJDK package needed to compile Android custom ROMs. When I run sudo apt-get install openjdk-7-jdk, the following error appears:
Reading package lists... Done Building dependency tree        Reading
state information... Done Some packages could not be installed. This
may mean that you have requested an impossible situation or if you are
using the unstable distribution that some required packages have not
yet been created or been moved out of Incoming. The following
information may help to resolve the situation:
The following packages have unmet dependencies:  openjdk-7-jdk :
 Depends: openjdk-7-jre (= 7u51-2.4.6-1ubuntu4) E: Unable to correct
 problems, you have held broken packages.
How do I fix this problem?
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Hakam El Assouad
  • 335
had the same problem too.. but i solved it with these commands:
sudo add-apt-repository ppa:openjdk-r/ppa
sudo apt-get update
sudo apt-get install openjdk-7-jre
muru
  • 207,228
Chris
  • 596
24
The one I did on 16.04 was:
For OpenJDK 8.X
sudo apt install openjdk-8-jre
For OpenJDK 9.X
sudo apt install openjdk-9-jre
Note: There was no openjdk-6-jre nor openjdk-7-jre for me on Ubuntu 16.04. Also there is NO need to install Oracle JDK (Actually OpenJDK is much better than Oracle one for me).
Luis Alvarado
  • 216,643
Some feedback with 16.04... If you are installing as part of a "software script" package, you always have to check which version of Java the programs support first.
For example, using openjdk-8-jre (newer version) on the install script.
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install openjdk-8-jre
