How do I configure a VirtualBox appliance to have its own I.P. address when running on a host Ubuntu machine?
I've tried following the solution for this question but am not having any luck: Getting I.P address of Ubuntu Server running in Virtual Box
Thanks in advance.
Fuzzy Analysis
  • 408
Configure your virtual machine adapter as Bridged Adapter.
Boot into your Ubuntu VM and run following command to get your IP address.
hostname -I
Now you can use ssh to access your server with that IP address or open-up website from your browser if you're running any web server.
If you want to add local network to your server aswell, then add Network Adapter 2 as Internal Network
Edit /etc/network/interfaces and add static adapter as eth1
auto eth1
    iface eth1 inet static
    address 192.168.0.1
    netmask 255.255.255.0
    gateway 192.168.0.0
When this is done, bring your adapter up.
ifup eth1
Gen
  • 933
