Today I tried to install Steam using sudo apt-get install steam.
It didn't work and showed me this error:
barend@barend-ubu:~$ sudo apt-get install steam
Reading package lists... Done
Building dependency tree
steam:i386 : Depends: libgl1-mesa-glx:i386
Then I tried sudo apt-get install -f to fix the broken dependencies.
That didn't work either.
I then searched on Google, and I found this question on AskUbuntu
The most upvoted answer suggested sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386 or sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-vivid:i386 libgl1-mesa-glx-lts-vivid:i386, neither of which work for me and fail with the following error:
barend@barend-ubu:~$ sudo apt-get install libc6:i386 libgl1-mesa-dri-lts-utopic:i386 libgl1-mesa-glx-lts-utopic:i386
indicator-bluetooth : Depends: unity-control-center but it is not going to be installed or
gnome-control-center but it is not going to be installed or
ubuntu-system-settings but it is not going to be installed
libgl1-mesa-dri-lts-utopic:i386 : Conflicts: libgl1-mesa-dri
libgl1-mesa-glx-lts-utopic:i386 : Depends: libglapi-mesa-lts-utopic:i386 (= 10.3.2-0ubuntu1~trusty2) but it is not going to be installed
Depends: libudev1:i386 but it is not going to be installed
libqt5feedback5 : Depends: libqt5multimedia5 (>= 5.0.2) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
It might be good to know that I tried to install Steam using the deb from their website, then it couldn't start because of an error, "You are missing the following 32-bit libraries, and Steam may not run:
libc.so.6" and I uninstalled Steam with sudo apt-get remove steam.
My question is: How can I install Steam again and fix the broken packages?
Update:
I tried what @Videonauth suggested, but it's still not working. A Terminal window popped up with this:
Steam needs to install these additional packages:
libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
I entered my password, and then...
[sudo] password for barend:
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.6)
Depends: libudev1:i386 but it is not going to be installed or
libudev0:i386 but it is not installable
unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
Press return to continue:
What do I do now?
Output of apt-cache policy libgl1-mesa-glx libgl1-mesa-glx:i386 as requested by @Videonauth:
libgl1-mesa-glx:
Installed: (none)
Candidate: 10.1.3-0ubuntu0.6
Version table:
10.1.3-0ubuntu0.6 0
500 http://ftp.nluug.nl/os/Linux/distr/ubuntu/ trusty-updates/main amd64 Packages
10.1.0-4ubuntu5 0
500 http://ftp.nluug.nl/os/Linux/distr/ubuntu/ trusty/main amd64 Packages
libgl1-mesa-glx:i386:
Installed: (none)
Version table:
10.1.3-0ubuntu0.6 0
500 http://ftp.nluug.nl/os/Linux/distr/ubuntu/ trusty-updates/main i386 Packages
10.1.0-4ubuntu5 0
500 http://ftp.nluug.nl/os/Linux/distr/ubuntu/ trusty/main i386 Packages
Update:
Thanks to all of you, @Videonauth and @Mark Kirby and @ijustlovemath who tried to help me out and I really do appreciate it, but nothing has worked for me so far. Hmm, no Steam for me, I guess...
If you advise me to do this, what would be the best way to clean my system up? I've installed and removed a lot of packages while trying all your solutions and I'm not sure if I can just sudo apt-get remove steam or have to do a lot more.
